Front Subframe Mount Washers
10 replies to this topic
#1 blackbelt1990
blackbelt1990
  • 2,626 posts
Posted 22 May 2020 - 12:38 PM
Hi everyone,
I’ve got the minispares poly mount kit for my front subframe. The teardrop mounts are replaced by a bush, washer and bolt. On assembling it today, it seems the washer isn’t up to the job, it’s not big enough and not thick enough. It’s easily bending under the strain and I think it’ll probably pull through.
Any thoughts?
Edited by blackbelt1990, 22 May 2020 - 12:40 PM.
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 May 2020 - 02:42 PM
It certainly wouldn't hurt to just throw a couple of bigger thicker washers on there.
#3 GraemeC
GraemeC
  • 7,475 posts
Posted 22 May 2020 - 02:47 PM
Or just solid mount it and get the advantages
#4 blackbelt1990
blackbelt1990
  • 2,626 posts
Posted 22 May 2020 - 02:51 PM
Considered it but it’s going to be a road car and I’m too old for that now ?
#5 GraemeC
GraemeC
  • 7,475 posts
Posted 22 May 2020 - 02:55 PM
Then stick with rubber - the poly ones are sh*t and you'll be replacing them again in no time.
I don't think solid mounting adds much to the NVH - that's how they were originally don't forget.
#6 blackbelt1990
blackbelt1990
  • 2,626 posts
Posted 22 May 2020 - 03:06 PM
I’ve already got rubber on the rear, they’re brand new so I don’t fancy swapping them to be honest. I’ll either get some bigger washers or swap for standard tear drops.
#7 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 22 May 2020 - 06:11 PM
Either go all rubber or all solid, no mixing and matching and no poly mounts either.
#8 blackbelt1990
blackbelt1990
  • 2,626 posts
Posted 22 May 2020 - 07:38 PM
Why no poly?
#9 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 22 May 2020 - 09:25 PM
Why no poly?
They either snap or delaminate quicker than the rubber type
#10 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 22 May 2020 - 09:28 PM
Here is a link to the poly front subframe toeboard mounts...
http://www.theminifo...ubframe-mounts/
Scroll down and there is a very clear image. Some images have been removed from the third party hosting site, so wont display.
#11 Dusky
Dusky
  • 5,322 posts
Posted 23 May 2020 - 09:29 AM
You see the poly mount going bad already.
