Correct Big End And Main Bearings For Turbo Engine
1 reply to this topic
#1 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 24 May 2020 - 04:34 PM
So im needing a little advice on best / correct type shell bearings that should be fitted into A+ metro turbo engine? I have taken some pictures of what is currently in. The questions are -
Are these correct?
What clearance should they have?
Are these oil groves correct? Read some info that they should not have oil grove in turbo??
What type are proven / preferred for turbo use? [I am not building a rocket. Its a tame almost standard engine]
any advice welcome
Attached File  IMG_1340.JPG   35.27K   2 downloads
Attached File  IMG_1341.JPG   38.07K   0 downloads
Attached File  IMG_1342.JPG   32.02K   1 downloads
Attached File  IMG_1346.JPG   33.33K   0 downloads
#2 mini13
mini13
  • 3,805 posts
Posted 24 May 2020 - 04:52 PM
Leyland swapped to thenn grooved bearings when they introduced the metro turbo, supposedly the non grooved bearing has 80% more load carrying capability according to dave vizard.
I would say that if your not building anything too mad then either bearing type would be ok,but if your replacing them then fit the non grooved ones.
In terms of clearance, I am for 1 thou clearanse per inch if diameter, so 2 thou on yhe main and 1.75 on the big ends
