Mega Piston
2 replies to this topic
#1 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 28 May 2020 - 09:56 PM
Hi
could do with a little advice on mini spares mega pistons, boost and CR. Im just a little confused that the mini spares site states 5psi boost and standard metro turbo was 7psi? Also i have my engine in bits to check CR. If others are using these pistons what boost do you run and what is your CR. I only intend a very standard engine with T3 and standard ish boost.
Rob
#2 mini13
mini13
  • 3,805 posts
Posted 29 May 2020 - 07:45 PM
ok, looking at that they say 9.38cc  I am pretty sure the original turbo piston was 12cc dish, so the increased compression ratio would sugest an decrease in boost wou;ld be needed, unless you intercool etc.
#3 Project_1275_GT
Project_1275_GT
  • Just Joined
  • 341 posts
Posted 31 May 2020 - 02:32 PM
Thanks for this. Looking like another week or so now until i have all parts to rebuild the engine and check CR. I will see what it works out at and maybe will be forced to use the intercooler.
Rob
