Trumpets/hilos
4 replies to this topic
#1 PACINO
PACINO
  • 821 posts
Posted 24 June 2020 - 05:37 PM
Hi guys! I can't remember it right now. How many milimeters you got when turning a completely 'nut' round?
#2 InnoCooperExport
InnoCooperExport
  • 372 posts
  • Local Club: Mini Seven Club Nederland
Posted 24 June 2020 - 05:43 PM
Using the Forum Search I found http://www.theminifo...hl=+hilo +turns
#3 PACINO
PACINO
  • 821 posts
Posted 24 June 2020 - 06:03 PM
Cheers man! Perfect and fast. A Salute
#4 Spider
  • 15,879 posts
Posted 24 June 2020 - 07:10 PM
I've measured the front ratio to be 4.5:1. The figure of 3:1, as best I can tell, was first published by Clive Tricky in the early 60's and sadly, it's been perpetuated ever since. The rears I have measured to be 5:1.
Hilos are not an original part and there's many manufacturers of them, so the threads on the Jacking Bolts do vary between some of these. All the same, it appears a commonly used bolt in many is an M20 with a 2.5 mm pitch.
If that's what your Hilos have, 1 full turn will adjust the front suspension height by (near enough) 11 mm.
#5 PACINO
PACINO
  • 821 posts
Posted 24 June 2020 - 07:24 PM
Thank you Moke! This's not for me, it's for a friend. He've just to fit HILOS in his Mini. I'll ask him what type of hilos has he bought.
