Fit Mechanical Oil Pressure Gauge
8 replies to this topic
#1 minicooperr
minicooperr
  • 277 posts
Posted 20 July 2020 - 04:42 PM
Having troubles fitting this gauge with leaks, I have got the t piece so I can keep an oil warning light also but what can I do to seal as I’ve use the fibre washer to the feed pipe to the gauge and this doesn’t seem to be leaking but in between the big t piece and the small adapter it is, any help to seal?
#2 nicklouse
  • 19,058 posts
Posted 20 July 2020 - 04:45 PM
Tighten it more as the adaptor is a taper thread. Some thread lock/sealer can help.
#3 whistler
whistler
  • 1,895 posts
ptfe tape on the threads but make sure you don't allow any to enter the oil feed.
#4 minicooperr
minicooperr
  • 277 posts
Posted 20 July 2020 - 04:47 PM
What thread locker would be suitable?
#5 MiniFanGraham
MiniFanGraham
  • 123 posts
Posted 20 July 2020 - 04:58 PM
i had same issue fitting mine, i used ptfe tape - both ends as had a leak at dash too (very messy) and did not over tighten but tight enough as brass screw thread gets damaged easily
i also used side exit of t-piece rather than straight ahead exit
#6 minicooperr
minicooperr
  • 277 posts
Posted 20 July 2020 - 05:01 PM
Is there any tips to getting out the crushed fibre washers as now I’ve taken it all apart it broke in half so want to replace it luckily I have a few but can’t get it out!!!
#7 nicklouse
  • 19,058 posts
Posted 20 July 2020 - 05:03 PM
use a pick
#8 minicooperr
minicooperr
  • 277 posts
Posted 20 July 2020 - 06:41 PM
Got it all apart now, I’m reluctant to use ptfe tape as I’ve seen conflicting information about it, I think a loctite would be more suitable something like 243?
#9 Spider
  • 15,848 posts
Posted 20 July 2020 - 07:57 PM
I gotta agree on the PTFE Tape. Yes, I just use 243. Most thread lockers will also seal, just don't use the Red ones.
