Running Rich
5 replies to this topic
#1 bajean
bajean
  • Just Joined
  • 125 posts
  • Local Club: Malta Mini Owners Club
Posted 20 July 2020 - 07:52 PM
So today I took the mini for its VRT ( aka MOT ) it passed from every single test without any advisory but it appears to be running extremely rich, so much so that in a mile or so it turned a fresh set of plugs black. The engine is a stock 1275 austin 1300 engine ( low cr ) with a mg metro "big valve" head ( not ported ), twin su hs2 ( using a M needle ) and a lcb manifold which goes into a 2" exhaust. The percentage was around 6-7 so quite high. I have gone ahead and ordered a set of EB needles which should lean out the mixture considerably, hopefully this fixes it as its got a completely revamped ignition system and a bunch of other new things. What do you guys think ?
#2 luismx123
luismx123
  • 525 posts
Posted 20 July 2020 - 07:53 PM
Turn the mixture leaner?
#3 bajean
bajean
  • Just Joined
  • 125 posts
Posted 20 July 2020 - 07:57 PM
Tightened them up all the way that decreased the reading from 8-9 to 6-7 so a step in the right direction.
#4 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 20 July 2020 - 08:16 PM
So are the needles correctly seated? I was going to add EB is the leaner needle but you've ordered those I see ...
#5 johnR
johnR
  • 2,322 posts
Posted 20 July 2020 - 08:20 PM
what air filters are you using?
#6 bajean
bajean
  • Just Joined
  • 125 posts
Posted 20 July 2020 - 08:46 PM
Everything has been rebuilt ( using the haynes manual ). I am using stub stacks at the moment. I went ahead and ordered them as I have seen them being mentioned a lot in the forums for a stock 1275 with twin hs2s
Edited by bajean, 20 July 2020 - 08:46 PM.
