Strange Current Leakage Between Sidelights/headlights And Hazards
electrical
3 replies to this topic
#1 zero_wlv
zero_wlv
  • 126 posts
Posted 23 July 2020 - 09:25 PM
Hi everyone,
BACKGROUND:
I've just finished installing a new main loom to my car  (1989 City).    Other work I've carried out at the same time is to   a) replace the short headlight looms    b) fit relays into the main beam and dipped beam circuits,  wired in the usual manner     c) re-wired the aftermarket alarm which had been done quite shoddily by the guy who sold it me and is hopefully safer now.     Dim-dip relay is bypassed at the holder under the dash if that's relevant,  but it's been like that for years.
I may have come close to narrowing down the source of the problem but still can't understand the logic behind it.
THE PROBLEM:
Everything seems to work perfect except for one strange thing:     there is a current leakage somewhere between the sidelight circuit and the hazards/indicators.
I know this because when I turn the sidelights or headlights on,   the two indicator bulbs on the dashboard glow dimly and there is no gauge illumination.    There is, however,  no detectable glow to the indicator bulbs themselves.   The sidelights and headlights themselves work perfectly,  all the time.
On the other hand,  when I turn the hazards on,   I hear the headlamp relays click,  the headlamps flash once and once only,  and then the hazards carry on working as normal!    Very strange!
The problem is intermittent - about 50% of the time these two strange things happen,  and the rest of the time everything works as it should.
I think I may have narrowed down the problem to the multiconnector which goes into the PCB at the back of the instruments.    The multiconnector which came with the new loom is very poor quality  (the rest of the loom is excellent).   It feels as though it's slightly too loose to make reliable connections. Sometimes I can get trigger these malfunctions by jiggling the connector.   However I'm really not looking forward to chopping this off and soldering the original one back on whilst the loom is in situ,   so I'd like to be certain first that this is where the problem lies.
Exactly how could bad connections at this connector cause the two malfunctions I'm seeing?
If the black earth connection to the PCB is dodgy,  could this somehow cause the sidelights to find an earth via the indicators?    Looking at the Haynes circuit diagram I really can't see how.    Is it doing this on the front wing or on the PCB itself?
Or could a bad red/green connection to the PCB cause this behaviour?
Or bad indicator connections to the PCB?
Note:   strangely,  the main-beam tell-tale light works without fail,  which I wouldn't have expected if there's a bad earth on the multiconnector.     Also the ignition light and oil light work without fail but I see from the circuit diagram that these don't rely on the black earth wire.
The problem can't be with the PCB as I've tried no less than THREE different instrument binnacles,  the same occurs with each.     Also,  I bench tested one before fitting and everything worked fine.
I don't think the problem can be in the new relay circuits I've fitted,  as these have nothing to do with any indicator wiring.
Similarly,  I don't think the alarm wiring's at fault because even though it's connected to the indicators,  it goes nowhere near the headlamp circuits and nowhere near terminals 7-8 on the fusebox.
How would I go about diagnosing this with a multimeter, test lamp or Sealey probe?
[Apologies for the long post,   conciseness isn't one of my talents]
#2 cal844
cal844
  • 9,733 posts
  • Local Club: TFMOC
Posted 23 July 2020 - 09:50 PM
First thing to do is to make sure you have all the earth connections clean and tight.
For fault diagnosis I use a power probe 3 as it has a voltage readout and you can feed power down wires to help find issues.
I don't know how I coped without mine
#3 zero_wlv
zero_wlv
  • 126 posts
Posted 23 July 2020 - 10:26 PM
Having just been staring at the Haynes wiring diagram again,   I'm thinking the PCB isn't being earthed properly,  it's starting to make SOME sense.
If you were,  for arguments sake,  to snip the black earth wire on the connector,   the current from the sidelight circuit would have little choice but to make its way through the indicator tell-tale lights.
Similarly,  any current from the indicator/hazard circuits would have little choice but to make its way through the main beam tell-tale light   (and presumably further towards my main-beam relay hence why the relay gets activated!)
#4 nicklouse
  • 19,055 posts
Posted 23 July 2020 - 10:30 PM
Do you have the dim dip resistor/relay thing on the inner wing support! Some cars have this that That turns the headlights on when the side lights  are on.
