Finally Got My New Project Home. 93 Cooper Spi.
46 replies to this topic
#1 exuptoy
exuptoy
  • 674 posts
Posted 25 July 2020 - 09:51 AM
Well, got the Cooper home and in the garage. I think he’s gained the name Tommy....Cooper :D (Viewers of a certain age will understand that one!
I knew when purchased that it has a few issues before I even start digging! First 2 issues are a clutch that doesn’t want to play and a clutch pedal that’s bent at about 20 degrees off centre due to some twonk forcing the pedal which doesn’t move, second is the huge oil leak, seemingly from the timing cover.
So I got it collected by a very nice polish guy local to me who is trying to set up his recovery business and collected for just £75 for a round trip of about 90 miles.
Attached File  4390872B-2692-4C20-8043-6E0FE6D0F8AC.jpeg   126.79K   10 downloads
So we got it home and I made sure I placed a tray under the cover and found a reasonable puddle in the tray the next morning. Seeing as I don’t want a garage floor full of oil I have decided to attack this first. A couple of hours in and this is the outcome.
Attached File  D29F7671-1825-4B96-9E9D-6919F74BE158.jpeg   123.32K   11 downloads
And this! The cover gasket was also plastered so the PO did try and cure it and when it leaked again they just covered all edges which did nothing to cure the leak.
Attached File  571A5FFA-E480-46D6-B443-75B91C47E3D2.jpeg   129.96K   12 downloads
I got it off this morning and there are quite a few bolt holes raised where it has been over tightened and the face isn’t flat. I’ve tried to square it up but would rather a new one. The cover it seems is discontinued and I can’t get one. So if anyone has one available please pm me and let me know as I don’t want to do this job again.
Edited by exuptoy, 25 July 2020 - 09:52 AM.
#2 exuptoy
exuptoy
  • 674 posts
Posted 25 July 2020 - 11:48 AM
Can’t get a cover so it’s been straightened out, paint stripped off and is quietly derusting in a citric acid solution.
Attached File  C32370E0-ACA9-4222-A899-780CD8708793.jpeg   97.79K   3 downloads
Attached File  9C05D55B-C2FC-4E78-87FC-C22A05DACC6A.jpeg   32.54K   3 downloads
#3 exuptoy
exuptoy
  • 674 posts
Posted 25 July 2020 - 01:49 PM
Took the parts out, dried them off, blew them down and threw some paint on them. Not too concerned about how pretty they are so long as they’re not rusty! Could have taken a bit more time but happy enough.
Just waiting on a gasket and viton seal now so I can refil with oil and see if it’s better?
Ordered a new genuine Verto slave and braided line too.
As a footnote I found someone has fitted braided brake lines and the Calipers have a link hose like the MG Metro vented ones. The discs aren’t vented so not sure if the caliper is standard?
Attached File  42FB4EA4-1639-4545-84C7-7B6414969A27.jpeg   61.33K   2 downloads
Attached File  6A05D57E-FCBC-4468-B2E8-2A06C5F5BF36.jpeg   38.39K   2 downloads
Attached File  6684C01E-12A2-42B3-B218-50F661F5F858.jpeg   100.51K   3 downloads
Edited by exuptoy, 25 July 2020 - 01:50 PM.
#4 I hate Brian
I hate Brian
  • 782 posts
Posted 26 July 2020 - 10:04 AM
Hi would you please take a few pictures of your cooling pipe setup stroke connections in the engine bay as I need to re-plumb mine back in after resto If you private message me I will give you my email address cheers
Edited by I hate Brian, 26 July 2020 - 10:05 AM.
#5 exuptoy
exuptoy
  • 674 posts
Posted 28 July 2020 - 07:44 AM
Got wind of a few mini spares lacally from. Guy who used to do auto grass so paid him a visit yesterday and picked up these JBW 7x13 Revolites and Miglia GF arches. I will obviously carry out a light refurb and may even carry out a colour change on them.
Attached File  6EFAB58A-501B-4126-A9E5-F85F31FE617F.jpeg   98.88K   4 downloads
Attached File  3FFA30F4-A3A7-44CB-8B14-C39D9FB5340A.jpeg   84.85K   3 downloads
#6 exuptoy
exuptoy
  • 674 posts
Posted 28 July 2020 - 05:21 PM
Stuck on 2 wheels earlier, offered up the arches and trimmed the rear as it looked over arched. I love the look.
Attached File  2D39FBD6-446F-4014-92B2-9E2837109A07.jpeg   115.23K   2 downloads
Attached File  4176EDBE-55A9-4D6F-B98B-35BCFCD1B5AC.jpeg   124.2K   4 downloads
Parts from Minispares not arrived so thought I’d take a look at the rust in the A pillar. Seems to have been bodged sometime in the past. Dug out some old fibreglass gloop and piece of steel stuck in there to try and reshape the rust!.
Attached File  1017EBEB-9F57-4866-B77D-271B290B1DB1.jpeg   86.6K   3 downloads
Decided rather than carry out further bodges on the scuttle and wing I thought I’d cut off the wing and A panel. £450 worth of heritage panels ordered thus far with MS.
Attached File  D070B152-7434-4D54-B2F2-32B65D9F1790.jpeg   127.46K   3 downloads
#7 mercenary62
mercenary62
  • 359 posts
  • Local Club: mini clan
Posted 28 July 2020 - 05:34 PM
looks like a great project ,good luck with it
#8 exuptoy
exuptoy
  • 674 posts
Posted 28 July 2020 - 08:18 PM
Cheers fella.
Edited by exuptoy, 28 July 2020 - 08:18 PM.
#9 johnR
johnR
  • 2,325 posts
Posted 28 July 2020 - 09:45 PM
Love the colours
#10 exuptoy
exuptoy
  • 674 posts
Posted 29 July 2020 - 04:47 PM
Decided to replace the whole front end. Ordered the remaining panels and started cutting near the seams then drilling out spot welds and peeling it all away. I think the plates on the flitch upright will be part of the new apron but for now they can stay until the panel arrives and I can check.
Attached File  CD832DA9-EABF-4CC7-8D2D-29E66C340983.jpeg   115.75K   6 downloads
My front corner also arrived which I’ll need to pick apart to repair the roof and upper screen surround and the new door frame should take care of the rest.
Attached File  153461A8-911A-4E5B-BB2D-2DEB844A38D6.jpeg   95.1K   5 downloads
#11 exuptoy
exuptoy
  • 674 posts
Posted 29 July 2020 - 09:41 PM
Spoken to Keith Calver regarding duplex timing gears and he advised that his IWIS simplex big pin timing chain is a straight swap for the standard SPi chain and I can retain my tensioner and gears and is suitable up to full race spec so I’ve ordered one from him at £32+ the dreaded and it should be winging its way to me as we speak. I’ve purchased a new genuine water pump and fitting kit so when my timing cover seal and gasket arrive it should be possible to rebuild it and get the motor back up and running before turning my attention to the sticking clutch.
#12 exuptoy
exuptoy
  • 674 posts
Posted 31 July 2020 - 07:40 PM
Thought I’d fit my new engine parts today, removed the water pump, removed the timing chain, cleaned the front plate ready for my new chain, started to reassemble and noticed some buffoon had placed too long a bolt in the top of the timing cover which has jacked out the plate bending it then damaged the thread!!! All back off then ordered a new front timing plate from mini spares.
Attached File  7B485B59-4D7D-4C26-9943-3E9D05284475.jpeg   110.86K   2 downloads
My new Calver heavier duty big pin IWIS chain.
Attached File  25D787E2-BD09-4902-BE5C-1A1F57ED53FB.jpeg   109.14K   3 downloads
Slightly annoyed I decided to pick apart the roof cut to salvage the bits I needed to repair my roof and screen surround.
Attached File  EE5D5344-8D5F-4BC9-84B2-F4BB7F28262B.jpeg   90.99K   2 downloads
Attached File  C0E26DC5-74D6-412D-9A7D-A3D18756366C.jpeg   94.16K   2 downloads
Also cut along the scuttle to see how bad the bulkhead was. I was pleasantly surprised.
Attached File  5DD49C26-C416-4D62-814F-4F6F01DF2345.jpeg   122.29K   5 downloads
I have to collect gas in the morning so I can make a start stitching the roof together.
#13 exuptoy
exuptoy
  • 674 posts
Posted 01 August 2020 - 01:46 PM
Got some qurust, etch primed and Rustoleum on the cant rail and inner pillar before sticking in this repair section. I’ll leave the A pillar until I have my new door frame.
Attached File  F9980C50-F8BA-4293-BEAE-3620A9F56145.jpeg   94.65K   3 downloads.
Attached File  10ED237D-CC42-4856-B311-2DAC6892A975.jpeg   98.07K   1 downloads
#14 exuptoy
exuptoy
  • 674 posts
Posted 20 August 2020 - 05:57 PM
Got my parts yesterday from @minispares so made a start putting the engine back together. New front timing plate and gasket, new IWIS big pin timing chain from Keith Calver, new timing cover gasket, refurbished timing cover with new Viton lip seal and new water pump and gasket. I assembled it all then realised I’d forgotten to fit the splash washer so had to remove it all again!?.
All back together with a quick change engine mount and fresh oil and filter and it starts on the button with no oil leak so far. Can’t run it too long as there’s no water or radiator fitted as I wanted to prove it’s dry before going further. Fingers crossed that’s the oil leak taken care of.
Rad tomorrow and clutch slave and braided hose then once it drives I can continue with the bodywork.
Attached File  1D6DA1DD-0220-4BDB-A801-C14B718BD4D4.jpeg   57.23K   6 downloads
#15 johnR
johnR
  • 2,325 posts
Posted 21 August 2020 - 04:29 PM
looks as though it's in fairly good nick?
