Finally Got My New Project Home. 93 Cooper Spi.
46 replies to this topic
#31 exuptoy
exuptoy
  • 674 posts
Posted 25 September 2020 - 04:47 PM
Got my A post cut out and cut n shut with a section from my magnum panel and ground back and after getting fed up of trapping the cables and water pipe for the washer bottle I decided to make a few cable retainers so they didn’t get melted or trapped when fitting the frame. I had to replace the washer pipe anyway as is was melted from when I started! I had a roll of VW stuff from when I had my Transporter facelifted so fitted that at the same time.
Attached File  EC66B989-7DCE-4CF2-83BB-14F0466D2449.jpeg   76.87K   2 downloads
Attached File  084855AD-E4EA-4737-AA1B-112223B446AF.jpeg   39.43K   0 downloads
Attached File  C944EDCF-0B67-48AC-B7D1-C96C7D7E391E.jpeg   55.7K   0 downloads
I borrowed a spot welder from a mate, got a few tacks on the frame and test fitted the door. All gaps look good so tomorrow I will complete the door frame install.
Attached File  03782EEE-96DC-4533-BEB7-940FB3114086.jpeg   69.42K   0 downloads
Attached File  6DB6C645-3C17-40F2-9DBF-738346138BB7.jpeg   52.27K   1 downloads
Attached File  0023E3B4-E4CF-4529-A37C-152E1AFF2D80.jpeg   49.89K   2 downloads
Attached File  A950CD3E-8B61-4603-B6F9-F0E88D0D6261.jpeg   51.94K   3 downloads
#32 exuptoy
exuptoy
  • 674 posts
Posted 26 September 2020 - 07:07 PM
Cut a piece to take up the gap in the lower B-pillar before welding it in. Got my rear arch to door repair welded in and dressed back, had an issue when shaping the lip around the curve where there was too much metal to made a relief cut and beat the excess into the void then welded it up.
Made a start spot welding the roof gutter and tidied a few welds up. Distortion is minimal. May have gone overboard on the spots though :D
#33 exuptoy
exuptoy
  • 674 posts
Posted 21 October 2020 - 05:27 PM
Been putting this job off so haven’t been in the garage since getting home from work. Been stressing on if I should strip the subframes out and turn it over on a spit.
Decided to flatten the lips on the rearmost end of the sill to allow it to sit under the rear subframe which means I can re-attach the new sills on the floor. Maybe when theres more strength in the shell I can rotate it, so started cutting out along the floor. My door brace is still attached to the crossmember so nothing has moved.
Attached File  C9881057-8B3B-446E-B0C6-8F20C2BA8BF5.jpeg   48.12K   0 downloads
steel RC40?Attached File  69942001-5351-45FE-9583-BE9A31B92386.jpeg   86.26K   2 downloads
That’s a lot of rot gone. Also scored a win on a secondhand exhaust for £50. Turned out to be a stainless
Attached File  B7193138-945E-4327-9EC1-382D3C9D1130.jpeg   62.53K   3 downloads
#34 exuptoy
exuptoy
  • 674 posts
Posted 22 October 2020 - 05:14 PM
Removed the subframe bolts of which both of them snapped! Cut the subframe mount panel out back to good metal with various tools in the confined space under the seat pan. Then I pushed the snapped bolts thru the new repair panel and copied the shape then cut and welded in place but only after positioning it with the subframe bolts through the subframe mount.
Attached File  D7E99342-E94C-45C3-B6C7-488A4BEB02A6.jpeg   41.09K   0 downloads
Next a few spot welds all on the doorstep to check the fit of the door (door skin is shot so it looks worse than it is).
Attached File  F1FBC012-F240-46DD-8290-CF7D4BCF717A.jpeg   50.72K   0 downloads
Attached File  6D42AF9D-EF73-4F0F-89AA-C7C357707E86.jpeg   52.19K   3 downloads
Trying to work out where to cut the floor to allow me to butt weld it in I marked a point 60mm in from the inboard edge of the sill with a steel rule and transferred that mark back 60mm on top of the floor, held my breath and cut out with a grinder at 45 degrees Fitzee style, this allowed me then to chop a wooden wedge 140mm high and block up the inboard end of the sill until it was flush and tack welded along its length. Not finished yet but not too much to do on the sill itself and the integrity of the shell is almost as it should be.
Attached File  D2919754-3CB7-4212-9631-2DF9F604A8D9.jpeg   73.86K   1 downloads
#35 exuptoy
exuptoy
  • 674 posts
Posted 23 October 2020 - 12:31 PM
Got my SH spot welder from a member on here who had emptied a body shop and this was surplus to requirements. It’s a Clarke CSW6T and I got it for £300 which is ok as they seem to fetch reasonable money so I don’t think I’d lose too much on it.
Attached File  34C27B3F-F0FB-4513-BFCA-BEB2434D4D99.jpeg   67.94K   0 downloads
Also started welding up the seam in the floor and grinding it back. Just gonna give the underside a flash over with a grinder and seam seal then Gravitex stonechip. Then I cut out the door brace followed by the seat crossmember. Just in the process of welding up where the crossmember was.
Attached File  E3859D8B-7D5D-4ADE-A5FF-F00149930FA4.jpeg   67.5K   0 downloads
Attached File  DD9627A7-B36F-40A6-93C4-D368C8E2D5E2.jpeg   56.4K   0 downloads
Edited by exuptoy, 23 October 2020 - 07:36 PM.
#36 exuptoy
exuptoy
  • 674 posts
Posted 23 October 2020 - 04:04 PM
Prepped the crossmember to stop it rusting and welded it in and gave it all a coat of etch primer to stop it flash rusting.
Attached File  D8B9C68A-09AE-4748-8551-398F516F7B37.jpeg   51.16K   0 downloads
Attached File  441FFD31-4DDD-455F-BE2F-BC8456341B5A.jpeg   45.25K   0 downloads
Attached File  E3B02930-E1ED-4607-9F8C-B53C92B70094.jpeg   48.29K   0 downloads
Attached File  E35C7CF8-7DEC-42E0-8784-87570691731B.jpeg   58.7K   1 downloads
Attached File  83A5063D-19AA-4B6D-AE97-34E3BC8268C7.jpeg   74.29K   2 downloads
Edited by exuptoy, 23 October 2020 - 04:05 PM.
#37 exuptoy
exuptoy
  • 674 posts
Posted 24 October 2020 - 03:27 PM
Continuing with the sill/floor repair, got a little more welded towards the front then tried to offer up my m-machine inner arch repair. Not sure what was going on as it was nowhere near, would probably have been better making it myself. However it’s what I had so straightened it out, drew on a few lines and reshaped it until it fit. Also placed a swage line down the centre to try and make it look like it was meant to be. Not perfect but not too bad. Once it’s fully welded I’ll use a hammer and dolly to dress it’s shape a little.
Attached File  8601EA41-541C-408F-BCA4-AA6D21138495.jpeg   66.49K   1 downloads
Attached File  1A302346-5E13-4E45-8AD7-F9B5C0387415.jpeg   55.81K   3 downloads
Attached File  67F515FA-6B56-40B5-BD67-1B0CE003AE8F.jpeg   69.75K   5 downloads
Attached File  47725BB0-CB1A-4E36-9D01-2096F114BB43.jpeg   81.38K   6 downloads
Edited by exuptoy, 24 October 2020 - 07:33 PM.
#38 exuptoy
exuptoy
  • 674 posts
Posted 08 May 2022 - 08:26 PM
Been back on it guys.
I did finish the quarter floor repair to fitch panel once I repaired my welder.
Attached File  802949C6-E713-476C-A95F-D29E5102483B.jpeg   62.27K   0 downloads
So this week I cleaned up the scuttle area and got it all clamped and lined up.
Attached File  AC20FC97-CFF5-4E76-91B7-A18C84DD085E.jpeg   124.56K   0 downloads
Attached File  339E2E1D-7124-4999-A6F7-26B50201DCF7.jpeg   129.71K   1 downloads
Then after mulling over removing the ears from the front panel and being left with scared original paper thin inner wings, I thought I’d cut out the crap and replace it.
Attached File  60D3E895-92C1-45C0-A971-867F3C8F9C6A.jpeg   64.39K   3 downloads
Attached File  63A9EAC4-7CF7-4780-A1AE-92CAA1F77037.jpeg   65.71K   0 downloads
#39 exuptoy
exuptoy
  • 674 posts
Posted 13 May 2022 - 08:52 AM
Productive day yesterday.
Got my NS lower inner wing repair completed.
Attached File  3C595383-C21C-4795-92F9-116EF47FFF2E.jpeg   48.26K   0 downloads
Attached File  B6908E7A-7D42-4800-B940-8DB1935B8352.jpeg   35.51K   0 downloads
Next up was 2x small repairs to the upper fitch before fitting the scuttle closing panel.
Attached File  28911FD8-320B-4D65-B773-D5F2BFB2691A.jpeg   75.48K   0 downloads
Welded the OS repair before seam sealing then painting with Bonda zinc rich primer.
Attached File  D648FAA4-EE2D-449B-8044-9EE57310BAE1.jpeg   49.19K   0 downloads
Attached File  0BBBCB89-C104-4162-9149-18B8207BDE12.jpeg   44.49K   1 downloads
And following my question regarding the front mounts, I thought I’d add a pic for anyone asking.
Attached File  AA61D0DC-4DD9-4A02-878A-33F9FC78EEED.jpeg   56.34K   2 downloads
And temp mounting of the front and wing.
Attached File  568DC4BF-B388-48E0-83D1-BC0A7E313358.jpeg   57.03K   1 downloads
Starting to take shape now.
Edited by exuptoy, 13 May 2022 - 08:56 AM.
#40 exuptoy
exuptoy
  • 674 posts
Posted 18 May 2022 - 09:14 AM
Yesterdays work.
C30-C6-BD9-5-BBD-4-DF4-9-F9-E-C9373-F8-D
348-D8429-130-B-4-D18-AC50-CDDE488-E549-
BCB8083-B-893-D-49-CB-9000-DA7-EF67-D257
0-AF49-EF9-0-BD4-4-C66-BEF5-D4198-EAD802
#41 elliot341
elliot341
  • 214 posts
Posted 18 May 2022 - 10:24 AM
Looks a good project, are you back on it to push it to a finish now?
#42 bpirie1000
bpirie1000
  • Area Managers
  • 2,567 posts
  • Local Club: Amoc
Posted 18 May 2022 - 10:25 AM
Another few jobs ticked off the list. Well done.
More time spent on it now means less time in the future..
Keep up the good work.
#43 exuptoy
exuptoy
  • 674 posts
Posted 18 May 2022 - 05:02 PM
Cheers guys.
Yeah, back on it as I’m fed up looking at it in the garage looking so sorry for itself.
The good thing is now I’m back on with it I’m enjoying the work and the more it progresses the more I want to finish it.
#44 exuptoy
exuptoy
  • 674 posts
Posted 18 May 2022 - 05:11 PM
Big milestone today. Front panel bolted up solid and gaps checked to ensure everything is lined up.
Scotched the rear of the wing and primed it and linished the seams back to bare metal before plug welding to the inner wing and a few spot welds along the surface of the seams to hold it all in place until I can set up my spot welder to do the backside of the front panel seams tomorrow.
Spot welds around the scuttle linished back below level so a nice bead of sikaflex should finish off the seam nicely.
AC38-D6-B2-CA33-48-F9-8512-CD5403-CCF7-D
A9-C0-BA4-F-6-C51-4-CC3-A912-C59-D7-DF21
6544-ADBA-EBC0-41-F2-BC15-C8407-FF8-C0-B
8-CA49-D90-7088-4-A2-E-B385-0992-F6929-B
Edited by exuptoy, 18 May 2022 - 05:12 PM.
#45 exuptoy
exuptoy
  • 674 posts
Posted 18 May 2022 - 05:35 PM
Anyone have a recommendation for an overpaintable flexible product to use in the wing to scuttle joint? Was thinking maybe Sikaflex that I’ve been using for seam sealer. Anything better out there?
