Arches And Cutting.
Posted 28 July 2020 - 11:40 AM
Posted 28 July 2020 - 11:51 AM
Posted 28 July 2020 - 12:20 PM
Posted 28 July 2020 - 12:24 PM
again it all depends on the fit of the wheels. the size means little the ET determines if the wheel sits out or in. as does if your drums are the correct ones to suit the disc set up. (built in 1" spacer).
Posted 28 July 2020 - 12:42 PM
Posted 28 July 2020 - 01:59 PM
Beware of quality as some don't fit well even with no body mods.....
Do any of these look like what you are after as I think Arc Angels are not cheap but look good quality?
https://www.the-arc-...gory&path=20_25
Most good quality front arches usually have enough flex in them to accomodate a cut at the front of the wing for full steering lock. Bear in mind also that the arch extension is usually hollowed out so does not need to exactly follow the clearance cut in the wing, ie. it overlaps to some degree without touching the tyre on lock. I have Wood & Picket arches which are not hollow as standard (as they screw from below to wing flange) and the hardest to fit but there was still just enough flex to adjust the profile to front bumper lip with 6x10 ET15 offset, see link below:-
http://www.theminifo...mini/?p=2910309
Edited by mab01uk, 28 July 2020 - 02:03 PM.
