Maniflow Piece
14 replies to this topic
#1 AlasdairM
AlasdairM
  • 240 posts
Posted 29 July 2020 - 05:54 PM
Hi folks, does anyone know what this is? It’s probably some sort of exhaust mount, but I don’t know where it goes.
It came with a stage 1 kit I just bought.
Attached File  1D20B312-5E3B-4F63-A22B-59EE44FEC17F.jpeg   84.12K   0 downloads
#2 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 29 July 2020 - 05:58 PM
I think thats the rear hanger...
#3 AlasdairM
AlasdairM
  • 240 posts
Posted 29 July 2020 - 06:05 PM
Any idea how it fits on?
#4 Ol timer
Ol timer
  • 331 posts
Posted 29 July 2020 - 06:06 PM
Rear hanger yes.
#5 sonscar
sonscar
  • 3,255 posts
Posted 29 July 2020 - 06:20 PM
Bobbins screw onto subframe and the curved bit hooks into an exhaust clamp around the tailpipe.Steve..
#6 AlasdairM
AlasdairM
  • 240 posts
Posted 29 July 2020 - 09:15 PM
Thanks a lot.
I was confused but I think I’ve got it now. They use a jubilee clip instead of a u bolt...
#7 Cooperman
  • 23,568 posts
Posted 29 July 2020 - 09:17 PM
Jubilee clip is not sufficiently strong. Use a U-Clamp.
#8 SolarB
SolarB
  • 1,406 posts
Posted 30 July 2020 - 07:32 AM
To be fair, I've used a Jubilee clip for years and it has never failed.
#9 AlasdairM
AlasdairM
  • 240 posts
Posted 30 July 2020 - 07:51 AM
Yeah and last night when I fitted it, it’s almost cosmetic as it doesn’t bear much weight
#10 sonscar
sonscar
  • 3,255 posts
Posted 30 July 2020 - 08:51 AM
U clamp fits into the groove on the bracket.Jubilee is insufficient.Steve..
#11 AlasdairM
AlasdairM
  • 240 posts
Posted 31 July 2020 - 10:16 PM
One more question... as you can see in the attached, the new exhaust sits very close to the fuel line. Is this normal? Is there a risk that the exhaust will melt the fuel line? Or does your exhausts sit that close to the fuel line?
Maniflow said it wasn’t a problem...
Attached File  104A90BC-8F31-495C-8F20-6597FB243488.jpeg   71K   4 downloads
#12 sonscar
sonscar
  • 3,255 posts
Posted 01 August 2020 - 08:24 AM
Is that the battery cable?and the brake pipe?I thought the fuel pipe was on the passenger side.The pipe from the mechanical pump to the carb is close to the exhaust but I have had no problems.If that is the battery cable I would look to securing it out of the was as bad things can happen if it touches.Good therapeutic fettling time required.Steve..
#13 SolarB
SolarB
  • 1,406 posts
Posted 01 August 2020 - 11:04 AM
Yes, that's the battery cable and it needs to be secured well away from the hot exhaust.
If the insulation melts and the cable grounds it's self to the body there will be lots of fun.
#14 AlasdairM
AlasdairM
  • 240 posts
Posted 01 August 2020 - 11:34 AM
Ok thanks, yes I checked and it is the battery. Silly me.
I will try and secure away.
#15 Compdoc
Compdoc
  • 612 posts
Posted 03 August 2020 - 12:05 PM
There should not be any brake or fuel lines, or battery cables near the exhaust.
