Have a few questions about it which I will ask here if no one minds and then if I don't get too much of a response will repeat in technical section.
1. How to cure a squeeking alternator. Only at tick over but quite loud. Is spraying it inside and out with WD40 OK.
2. The tops of the doors seem to have bent out slightly causeing them not to seal prperly and there is a small crack where the window frame joins the door panel at the rear of the passenger door and the fron of the drivers door, both on the inside. How easy is it to realign and weld these.
3. Squeeking gear lever linkage housing. Assume one of the mounts are loose or need relacing. How easy to do.
I used to do a lot of my own car maintenance but have not done a lot recently due to modern cars being so damn complicated. Can't wait to get stuck back into something which is a bit more basic.
Cheers in advance and there will probably be more questions later.
PS forums are great places for info
