Posted 19 June 2010 - 04:06 AM
So its been a while since I last updated this.....
Even as a rolling shell the car has been getting a lot of attention, every time a customer walks in to my dads garage they stop and look and ask questions about it. "Is it going to be a show car?" ....... "No !"
After getting the car on the wheels it was instanly clear that I was going to have problems with wheel clearances, and I hadn't even lowered the suspension or fitted the arches yet. Due to the build schedule I didn't have time to test fit anything, so i was kind of expecting it. The wheels looked too wide for the arches, and on full lock they rubbed the front wings. But I have to have those wheels, so I'll sort that out later (the arches were still at the painters anyway).
At this point I hadnt started the engine yet, as there were still wiring issues to be resolved which I needed help with.
While I was waiting for my dad to become free, I cracked on with anything else that needed doing, which was everything.
Mounted the exhaust, 2" custom centre pipe and 2" back box (loud but not ridiculous), door seals, locks, window meachanisms, door windows.
I also fitted sound deadener on the roof and inside the bulkhead. I used a product called FatMat, its pretty similar to Dynamat, but much cheaper. When you tap on the roof after fitting it the difference is amazing. It takes a long time to get it done right but if you take the time its worth it.
The bulkhead is the hardest part to do. Before I started I made some blanking plates to go over the cold air inlets for the dash. I kept the one for the heater but I am going to have speakers in the dash where the vents go. The sound deadener needs to go EVERYWHERE. the easiest way to do this is to make paper templates of the areas you are going to cover. Keep ever little extra piece that you dont use as you will find little gaps as you go. I used 40sq ft to do the roof and bulkhead with some left over to put some on the inside of the door skins.
I got the arches back from the painters and after putting them on and lowering the suspension the car looked great. The wheels were about 2cm from the bottom of the arches and sticking out 1/2"inch. Perfect.
When it came to fitting the headliner it was a nightmare. The body shell came with one fitted already, so I tried re-fitting that but as it turned out I hadnt been fitted properly and was too short in the back, so I had to buy a new one. I could have fitted it myself, but i wanted it done right so I sent it and the car off to have it done professionally and got it back the next day.
So after the headliner was in I had the windows fitted. I also had it done by a professional as its easy to crack the windows if you dont do it right, he also fitted new seals and added a special sealant that is use in fitting modern windscreens to ensure it won't leak. I used all the glass from the original car, its not in perfect condition, but at this stage in the project it just needs to be watertight.
After sorting out the wiring it was time to start it. It started instantly the first time and ran smoothly. We let it run for a little while, it didnt overheat. Time for a test drive.
My dads garage is on private property so I took it for the first drive, got 10 ft, wheels were rubbing. Raised the suspension by 2 cm, better. It had been a long time since I had driven it, but I could instantly feel the difference in the engine. I wasnt putting my foot down hard as it still need running in but wow. It had a little backfire out the carb but a good first run. The sound of that exhaust is fantastic, loud enough without sounding like a fart in a tin can, and when you take your foot off the throttle you hear that little popping sound like a rally car (timing a little off).
I got to the end of the little alley way slammed on the brakes and it stopped straight away, Fantastic! I'm never driving a Mini with front drum brakes again.
So I had to turn around and go back. Big problem. 3 point turn became a 7 point turn because the wheels were rubbing.
So thats as far as I got. My plan was to get it as close to M.o.T ready as I could before the 29th of May and I easily made it. I could have done more but I ran out of time to get the other parts delivered.
I am now in New Zealand, working and skiing, and while I am away the Mini will be going back tothe painters. They are giving it a few touch ups and a propper polish and are going to adjust the arches for the front wheels.
When I get back hopefully all it will need will be a day or so's work and I will be able to drive it......... I'm just going to have to wait 4 months for it though......
Then part 2 ...... the interior.
