what??
22 replies to this topic
#16 1984mini25
1984mini25
  • 8,785 posts
Posted 17 February 2006 - 07:42 PM
I would get a Haynes manual which goes into detail of how to adjust them. Better still, get a TMF CD, they have got loadsa info on them!
Or see below
idiots guide to "Tightening Tappets"
It will facilitate turning over the engine if the spark plugs are removed at this point. Suitably label the plug leads to ensure they will be reconnected correctly.
The valve adjustments should be made with the engine cold.
The importance of correct rocker arm/valve stem clearances cannot be overstressed as they vitally affect the performance of the engine. If the clearances are set too wide, the efficiency of the engine is reduced as the valves open late and close earlier than was intended. If, on the other hand the clearances are set too close there is a danger that the stems will expand upon heating and not allow the valves to close properly which will cause burning of the valve head and seat, and possible warping.
For this operation the engine can be turned over by engaging reverse gear and pushing the car backwards, or by jacking one of the front wheels clear of the ground and rotating the wheel. In this latter case, top gear should be engaged.
Crankshaft rotation is clockwise, viewed from the radiator end of the engine.
Rotate the crankshaft until each valve in turn listed in the left-hand column below is fully open (spring compressed), then check the clearance of the valve listed opposite in the right-hand column. Valve numbering is from the radiator end of the engine.
Valve No. 1 open check valve No. 8
Valve No. 3 open check valve No. 6
Valve No. 5 open check valve No. 4
Valve No. 2 open check valve No. 7
Valve No. 8 open check valve No. 1
Valve No. 6 open check valve No. 3
Valve No. 4 open check valve No. 5
Valve No. 7 open check valve No. 2
The valve rocker clearance should be 0.012 in (0.305 mm) for both the inlet and exhaust valves (cold). The clearance is correct when the appropriate thickness of feeler gauge is a neat sliding fit between the end of the valve stem and the pad on the rocker arm.
If adjustment is necessary, slacken the adjusting screw locknut with a ring spanner, and turn the adjusting screw on the push rod end of the rocker arm until the correct
Gap is obtained
Turn the screw clockwise to reduce the clearance, or anti-clockwise to increase it. Retighten the locknut while holding the adjusting screw with the screwdriver to prevent it turning, and then recheck the gap.
When adjustment is complete, refit the rocker cover. Use a new cork gasket if necessary.
#17 AlexM
AlexM
  • 1,302 posts
  • Local Club: NMOC, ECMC
Posted 17 February 2006 - 09:16 PM
Is this recommended if you have very worn rockers? :o like i do :crazy: maybe it will curb the irritating tapping noise, i should probably replace the timing chain too
#18 1984mini25
1984mini25
  • 8,785 posts
Posted 17 February 2006 - 10:53 PM
I’ve been doing mine every 3k as part of a mini service
Where I just go over the car checking everything and hopefully replace things that are worn before the break
Been running really nice and quiet
The timing chain is normally quiet almost silent unless it’s worn then you know about it
as it then rattles on the inside of the casing and the engine will not run very well
#19 josh_tacon
josh_tacon
  • 123 posts
Posted 18 February 2006 - 06:48 PM
iv just set the tappets on mine to the recomended 12 thou but i still get the horrible tapet sound!!
could this be due to the rocker shaft being worn?
also what is the torque setting of the rocker shaft?
cheers
josh
#20 icklemini
icklemini
  • 2,982 posts
Posted 18 February 2006 - 07:46 PM
cheers
josh
Yeah the shaft could well be worn - back off a rocker and slide it against one of the springs and see what state the shaft is in where the rocker acts against.
#21 davexdavexdave
davexdavexdave
  • 650 posts
Posted 19 February 2006 - 12:17 AM
ok thats great thanks everyone i will have a go at it on tuesday!! i'll get back to you!!
#22 davexdavexdave
davexdavexdave
  • 650 posts
Posted 21 February 2006 - 03:52 PM
right just had ago at setting the valve clearances and well to be honest got bored then it started raining so i put it all back together and came in. i was wondering if i took my car to get it rollin road tuned would they do this for me??? because i really canny be assed and im gona get it rollin roaded soon anyway.
#23 Jammy
Jammy
  • 25,397 posts
Posted 21 February 2006 - 03:56 PM
LOL!! Thats the kind of half assed approach that will keep your mini on the road!!
Yea, they should be able to do this at a rolling road.
