Mk1 fiesta caliper conversion
#31
Posted 29 May 2005 - 09:53 PM
#32
Posted 30 May 2005 - 08:01 AM
#33
Posted 30 May 2005 - 08:39 AM
#34
Posted 31 May 2005 - 04:43 PM
Anyway i recon this is a very worth while conversion so im going to write a sort of instruction manual for it so you lot dont have to figure it out for yourselves.
#35
Posted 31 May 2005 - 07:48 PM
#36
Posted 09 June 2005 - 03:35 PM
#37
Posted 09 June 2005 - 07:10 PM
My cars a 93 so has discs already. Would i have to do the complete conversion inc the metro hubs etc and can i keep my servo?
#38
Posted 09 June 2005 - 09:03 PM
austin68; you can keep everything appart from your calipers and hoses and you modify your existing hubs.
Chris
ps. the brakes are really great now they have bedded in!
Mk1/2 fiesta calliper conversion,
for 8.4” mini brakes to allow 10” wheels
Parts required
· Mini (84 on); Standard disks,
Hubs,
Driveshafts / cv’s
Drive flange mounting bolts
· Metro (80-90); Vented disk brake drive flange
· Fiesta (76-89); Mk1 (76-83) calipers and mounting bolts or
Mk2 (83-89) callipers and mounting bolts
· Brake hoses; Full custom hoses with standard mini on the subframe end
and m10x1 on the calliper end and 32cm long
Moquip part numbers; Tel. +44 0208 568 1172
Bulkhead fitting HETBF1-3 x2
Bulkhead nut BNS5/8W x2
Hose end E321-3 x2
Converter from imperial to mm MMS5-3-31 x2
copper washers WC-3/8 x6
Airoquip hose TFE3 32 32cm
Modifications required
· Turn standard 8.4’’ disks down to 7.9”
· The hubs need to have a mounting face put onto the opposite side of the calliper mounting lugs parallel to the original and the mounting holes need to have the threads drilled out (10mm drill is perfect) for clearance for the fiesta bolts.
· The drive flanges need to have the wheel locating lugs removed, if they have them, so that mini wheels can be fitted (some alloys will fit without them being removed but you’ll have to check)
· The web on the calliper mounting bracket needs to be ground away a little for clearance on the hub. Its clear how much needs to be removed when offering it up to the hub.
#39
Posted 10 June 2005 - 08:47 PM
But please check with your insurance company that they will accept this mod as i made the mistake and have had an insurance claim invalidated as a result
#40
Posted 23 July 2005 - 08:08 PM
Pleeeaaassseee
#41
Posted 03 January 2006 - 11:19 AM
im hoping to go to tens in the next few weeks, and i need to sort out some brakes! these fiesta brakes are sounding like a REALLY good idea!
any mroe info on how you are getting on with them would be great!
thanks
nick
#42
Posted 03 January 2006 - 07:00 PM
#43
Posted 04 January 2006 - 10:21 PM
#44
Posted 05 January 2006 - 12:02 PM
#45
Posted 05 January 2006 - 12:24 PM
