Many thanks!
mini.jpg 79.41K
22 downloads
Posted 05 September 2009 - 12:46 PM
mini.jpg 79.41K
22 downloads
Posted 05 September 2009 - 01:18 PM
Posted 05 September 2009 - 01:42 PM
Posted 05 September 2009 - 01:56 PM
You have bought a 1275 waterpump for a 998, you have blocked the bypass to the head, without the bypass you will experience overheating (which is bad) because the water is not circulating around the entire engine (until the stat opens), I would recommend getting a proper 998 pump with the bypass.
Paul.
Posted 05 September 2009 - 01:57 PM
for now to save changing waterpump again so soon, you could remove the thermostat and drill 6 small holes around the flat perimeter of it, so that water can travel up through and past before the stat opens, i have done this before and had no problems at all
Posted 05 September 2009 - 05:55 PM
Edited by Pauly, 05 September 2009 - 06:07 PM.
Posted 05 September 2009 - 07:32 PM
Posted 05 September 2009 - 07:36 PM
Posted 05 September 2009 - 07:46 PM
Many many 1275s have the bypass connection!!!!!!!!!!!! But it's EXCELLENT to do away with it - much faster warm up and far far better heater in winter. Just drill ONE 1/8" hole in the stat rim (6 is far too many) - and keep the heater valve open.
Posted 05 September 2009 - 07:50 PM
Posted 05 September 2009 - 07:52 PM
I agree, loads of 1275's have a bypass... and the bypass hose usually fails ... do away with it!
Chris
Posted 05 September 2009 - 07:53 PM
If its a 1275 then why has it got a bottom bypass on the head? 1275's dont have that sort of bypass? they either run a sandwich plate between the stat housing and head face or as said you drill holes in the stat. They dont have that sort of bypass, unless its a 1275 with a 998 head
Ive heard of some people not running some sort of bypass and they run fine but its bad practice to not have the water circulating though the head, the head will hold the water untill the stat opens. Does your car get up to temp very quickly?
If your stat fails it will overheat very quickly.
Paul.
Posted 05 September 2009 - 07:55 PM
Posted 05 September 2009 - 09:40 PM
Posted 05 September 2009 - 10:24 PM
