Show Me The Light!
28 replies to this topic
#1 djshongo
djshongo
  • 260 posts
  • Local Club: None Yet!
Posted 20 November 2009 - 11:28 AM
Model:sprite
Year:1993
Description of problem (please be as in depth as possible):how to light up interior?
Hi folks,
Just looking to see if anybody has lit up the interior of the car in any way. As we all know, the switch panel of the mini is desperatley missing sum light, esp at night time! :shifty:
Was thinking about doing something about this, maybe wire up sum switched lights..?! Suggestions?
johnny
#2 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 20 November 2009 - 11:32 AM
minispares/ moss
do a illumination kit which lights your switchs up....have look :shifty:
#3 Min E
Min E
  • 226 posts
Posted 20 November 2009 - 11:54 AM
Danny's fitted flat, blue LED strip lights under the parcel shelf on both sides, wired up to the panel/side light circuit.
Depending on what dash you've got you could perhaps fit some sort of 'downlighter' over the switches. A bit like a small numberplate light.
#4 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 20 November 2009 - 11:55 AM
Good idea
#5 djshongo
djshongo
  • 260 posts
Posted 20 November 2009 - 12:39 PM
yea was thinkin of sumthin like that!
just gotta figure out how to do it now! :shifty:
#6 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 20 November 2009 - 12:45 PM
Minispares sell a proper kit for this exact situation (as pointed out by 'cooperdan'), that only requires novice level of skills to install and leaves you with a professional, reliable system.
It really is the tidiest, most aesthetically pleasing method of getting your switch panel illuminated..... but it may not be the cheapest.
#7 djshongo
djshongo
  • 260 posts
Posted 20 November 2009 - 12:53 PM
Been on there, but cant seem to find the right thing :s
All I can see is the switches for sale seperatley.. am I blind lol
#8 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 20 November 2009 - 12:54 PM
....It's the first Product that appears if you search for 'Illumination'.
#9 newdawn1st
newdawn1st
  • 1,268 posts
  • Local Club: Fylde Mini Club
Posted 20 November 2009 - 12:56 PM
10 seconds later, bam! :shifty: Here you go >>clicky.<< searchs are a wild beast and you need to know how to tame them :)
#10 djshongo
djshongo
  • 260 posts
Posted 20 November 2009 - 12:58 PM
got it! I was on the wrong mini spares site... doh! lol
#11 djshongo
djshongo
  • 260 posts
Posted 20 November 2009 - 01:03 PM
Ohhhh that looks nice! And the wee chime is a real seller! Anybody fitted this?
I dont think all of my switches CAN light up?! Thought they were solid plastic :shifty:
#12 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 20 November 2009 - 01:12 PM
Depends what you have fitted, but the Hazard switch lights up, the brake fail lamp test switch will light, and so will the rear screen demister (if fitted), fog lamp switch (if fitted)
the headlamp switch is usually blank...
#13 newdawn1st
newdawn1st
  • 1,268 posts
Posted 20 November 2009 - 01:16 PM
Would I be right in thinking that it uses the telltale bulb for this purpose then? If so doesn't it kind of defeat the purpose of the brake fail lamp test switch>
#14 djshongo
djshongo
  • 260 posts
Posted 20 November 2009 - 01:17 PM
Yea you're right, my headlamp switch is blank :shifty:
Im sure i could buy one with a light tho?
#15 Min E
Min E
  • 226 posts
Posted 20 November 2009 - 02:12 PM
This:
http://www.minispare...00/MSSK2007.jpg
Appears to actually light the bulbs that are bult into the switches themselves...Yes?
That could be very confusing if you actually needed to have one of the switches 'on'
But...If that was what you wanted to achieve you wouldn't need to go to the expense of a 'control boxed' kit.
Each of the switches has a small contact on either side, one is earthed the other is fed from the harness of the item it is switching.
Simply unclip that feed, insulate the wire with heat shrink tubing or simmilar, and then loop a feed to each of the switches with a wire from the side-light circuit.
Hey Presto!!!!!Job done....free....and you'd have to do all that work to fit the kit anyway.
Having said all that above I have realised that to have the bulbs alight all the time would probably damage the swich from the contained heat they produce.
When you think about it the illuminated switches are all on items that are only suppsed to be on for a short time which is probably why the headlight switch itself is not illuminated.
One idea to perhaps alieviate the heat problem would be to use a voltage dropper resistor and a diode to feed the bulbs and then they would just glow and then get brighter when they were swiched on.
I'll put my thinking cap on and try to come up with a simple circuit.
Edited by MINY, 20 November 2009 - 02:32 PM.
