Clutch Removal ?
8 replies to this topic
#1 connor_bristow
connor_bristow
  • 12 posts
Posted 25 February 2010 - 06:15 PM
1275 sprite
1994
hi there i am having trouble removing my clutch as it is different to all the ones in the manuals.
i have removed the clutch cover
i have removed the central flywheel bolt and lock washer behind it
i have removed all bolts around the outer edge, releasing the flywheel but the clutch plate still will not come off even using a puller.
any help ??
cheers
connor
#2 GraemeC
GraemeC
  • 7,467 posts
Posted 25 February 2010 - 06:25 PM
Have you also removed the big keyed washer from the end of the crank (under the bolt and lock tab)?
The puller will need to be very tight - you'll need a long breaker bar to get enough force on it.
#3 david036
david036
  • 188 posts
  • Local Club: warton
Posted 25 February 2010 - 07:17 PM
One of mine took over 2 days to come of and then decided to go with that much force it jumped about 10ft across the workshop!!!
#4 steverose
steverose
  • 229 posts
Posted 25 February 2010 - 07:38 PM
I think I was luck with mine it came off easy. But I did put the puller on and put it under a load and left it over night then put a long breaker bar on the next day and it popped off, but it will come off with a bang. The key I found was being able tohold the engine steady while your pushing the bar round, I found using a foot helped :-
#5 connor_bristow
connor_bristow
  • 12 posts
Posted 27 February 2010 - 07:57 AM
yes i have removed the keyed washer and i now have a puller on it applying 10 tons of force - we shall see what happens :thumbsup:
#6 Pauly
Pauly
  • 4,213 posts
Posted 27 February 2010 - 06:40 PM
Make sure the puller is straight and paraell to the flywheel, otherwise you will be pulling at an angle and it wont work.
#7 connor_bristow
connor_bristow
  • 12 posts
Posted 08 March 2010 - 08:03 PM
just to let you know i have got hold of a proper puller and is now on tight, and left for a couple days, will tighten it up again tomorrow - and yes it is straight lol.
#8 Pauly
Pauly
  • 4,213 posts
Posted 08 March 2010 - 09:00 PM
Also give the middle and outer puller bolts a knock with the hammer :(.
#9 connor_bristow
connor_bristow
  • 12 posts
Posted 09 March 2010 - 08:39 PM
Also give the middle and outer puller bolts a knock with the hammer :).
got a proper puller on it gave it a good wack with a hammer and it popped off - thankyou all for the tips :thumbsup:
