Arches For 10" Steels?
16 replies to this topic
#1 project mini chris
project mini chris
    have a break, have a...
  • 1,894 posts
Posted 28 July 2010 - 07:13 PM
What arches would suit 4.5x10 cooper S reverse steels? :) i was thinking group 2's but imm unsure, and if anyone has any pics that would be great!
Thanks :P
#2 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 28 July 2010 - 07:15 PM
You wont need arches , i got 5.5x12s and they only just go past by maybe like 1mm?
You could just use one of those chrome strips or spacers for group 2s
#3 Boycie
Boycie
  • 1,978 posts
Posted 28 July 2010 - 07:19 PM
You will need arches if you're running 4.5x10" Reverse Rims if you have front disc brakes.
I have them on drums and they are only just within the body line.
It's all about offset of the wheel, and the reverse rims have plenty- in fact, they were designed to give non-'S type' Minis the same track as the disc-brake models, which push the wheels out an extra inch at the front.
#4 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 28 July 2010 - 07:22 PM
OMG , I was thinking about needing the 7.5 Cooper S discs to use 10s but then didnt think about me being on drums all round that my wheels would be in more
Sorry Chris :P
#5 project mini chris
project mini chris
  • 1,894 posts
Posted 28 July 2010 - 07:23 PM
cal i want arches, later minis look pants without them :P
Boycie- Thanks for the info, yes i will be running s disc conversion on the fron but does that mean i will have to run minifin spacered drums on the back to give the same sort of spacing? :)
Edited by project mini chris, 28 July 2010 - 07:24 PM.
#6 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 28 July 2010 - 07:29 PM
You should already have a spacered rear drum , because you have discs on the front.
#7 project mini chris
project mini chris
  • 1,894 posts
Posted 28 July 2010 - 07:31 PM
thats the thing tho i dont? i checked them the other day and theyre non spacered :/
#8 Boycie
Boycie
  • 1,978 posts
Posted 28 July 2010 - 08:06 PM
Hmmm that's odd- as Bradley says, a car of your vintage should have 8.4" discs up front with spacer drums at the rear.
In fact, if the car is on the original steel wheels (or ever Rover minilights etc) then it MUST have the rear spacer drums- otherwise the standard 12" wheels hit the damper/ radius arm :P
#9 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 28 July 2010 - 08:07 PM
Yep , like they do on mine lol :)
#10 project mini chris
project mini chris
  • 1,894 posts
Posted 28 July 2010 - 08:08 PM
well i lie, the drums i have on the back are almost level across accept for a slight and i mean slight bump which the steel sits on, and i have researched and this isnt normal :)
#11 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 28 July 2010 - 08:09 PM
Maybe get some pics up , might help
#12 project mini chris
project mini chris
  • 1,894 posts
i will get gav to tommorow
#13 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 28 July 2010 - 08:10 PM
Spacered ones
http://minispares.co...a...5841&title=
Non spacered
http://minispares.co...a...6485&title=
Might be different colours , rusted etc but the shape will still show the difference.
#14 Boycie
Boycie
  • 1,978 posts
Posted 28 July 2010 - 08:18 PM
Actually, I've always slightly wondered about this...
the spacered rear drums don't seem to provide as much track increase as the disc brake front hubs/ drive flanges do over the standard flat drums.
Does this mean that on disc/Cooper S cars, the rear wheels are more inboard compared to the fronts than on all-drum cars?
Sorry for slightly jumping on your thread OP!!! Martin (MRA) or someone will surely be able to answer all the questions! :P
#15 project mini chris
project mini chris
  • 1,894 posts
Posted 28 July 2010 - 08:19 PM
Spacered ones
Non spacered
second ones are the ones i have :P weirdd..
im getting minifins later anyway :)
