Stalling after tyre change.
6 replies to this topic
#1 nev_payne
nev_payne
  • 2,249 posts
Posted 08 March 2006 - 07:12 PM
Well I'm phoning up the tyre garage tommorow thats for sure. :xxx:
New pair of Falklens on the front today - great stuff - out with the misshaped tyre, more grip, good stuff - light at the end of the tunnel?
Pffff....your kidding.
After the garage finished I backed it out of the bay onto the single road with the mekki behind to guide me out. Stall 1 - thought nothing of it, I wasn't exactly reving enough for the reverse to drive properly - started up again and hey presto we're off up the hight street and back to work. :D Stall 2 - this time I thought it must be the wet so out came the choke to get some bumph into the engine. :- Out of work, and Stall 3 - this is getting rediculous. :( A further 5 stalls on the way home with slowing traffic, traffic lights and not using the accelerator. :xxx:
So im at home thank god, after using far to much fuel keeping the engine in high rev. From what I could muster, these are the features of my current serious problem:
- Stalls under 30MPH if theres no acceleration.
- 2nd and first gear need choke.
- When not using accel. pedal, engine can be felt "stuttering" sort of pulling and pushing the car in short sharp bursts. This isnt a pump failure as such- I have had that before the engine simply wont budge.
- When stalling, used the chocke to push the engine to catch - when it does, just the slightest choke (1/4" out) gives a very high rev - almost like theres excess fuel in the system. :dontgetit:
- Spots will go out when stalling regardless of light system being on, then come back on when car begins to move again.
- From standing to moving, or any gear change for that matter, clutch seems slower to catch than normal.
Any help would be great folks, and quick!
Nev.
#2 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 08 March 2006 - 07:17 PM
have you changed them ht leads yet? check battory cable under car is not shorting out and check wires under bonnet for good connection
dave
#3 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 08 March 2006 - 07:21 PM
I doubt the tyre change has caused these symptoms, I suspect it is coincidental more than anything.
It sounds like your car needs a tune up, what general condition is it in under the bonnet?
Like Dave has said ^^^^^, it is 'possible' that the battery lead has been caught with a jack and is now shorting under the car, check that. Check that it hasn't had a fuel pipe crushed too (I guess that's possible, if some one was really careless with a jack) :D
#4 nev_payne
nev_payne
  • 2,249 posts
Posted 08 March 2006 - 07:27 PM
I intend to change them over tommorow - could it simply be all the wet weather?
MiniMadMe - heh coincidental is a word George uses a lot - fix one thing, the next thing goes - its like he's playing games with me! :D
#5 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 08 March 2006 - 07:56 PM
could very well have been just the crappy weather
#6 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 08 March 2006 - 08:45 PM
yep damp ht leads will cause those problems
dave
#7 nev_payne
nev_payne
  • 2,249 posts
Posted 09 March 2006 - 05:38 PM
Changed them over at lunchtime today :ph34r: what a result! Sounded more like a sewing machine than a dying animal :w00t:
One lead in-particular - think it was the coil to dissy lead was severely corroded and absolutely drowned in grease and muck :D no wonder George was having trouble!
