Posted 30 March 2007 - 01:44 PM
I would start from scratch.
Get your leads in the right order. As Syholl says as you look at the dizzy, the HT lead thats at the 2 o'clock position goes to the cylinder nearest the rad (the right side as you look at the engine from in front of the car, just in case you have the rad in some strange position! lol ). Then, as above, working anti-clockwise around the dizzy, it goes 3, 4, 2. The leads should not go in any other sequence.
Then make sure you've got the timing set up correctly, with piston 1 at top dead center (take the spar plug out and keep sticking a screwdriver in to see where top is, or take the rocker cover off to see when the spring is depressed the most). Then use the timing marks to turn the engine on til your at 8 degrees of crank rotation (8 degrees is always a good starting point). Now, you want to turn the dizzy so that HT lead 1 is smack bang on top of the rotor arm (which should be pointing roughly towards cylinder 1).
If its still not starting take each spark plug out in turn, place it on the block (I place them where the engine number is stamped above the alternator) and make sure your getting a spark to each plug. If you not, swap over the plug and then the HT lead with one where you are getting a spark to find out which component is faulty and replace.
I find constantly trying to start the engine will have quite a drain on the battery, so I usually have the mini wired upto another car ticking over via jump leads.
Remember, where gloves when handling HT leads and plugs, wouldn't want to get zapped.
Sorry if some of the above seems a little simplistic for you (I don't know how experienced you are), but you should be able to get it at least started by following the above.
