Eaton M45 Used To Blow Through A Webber Ideas Pls
Posted 04 June 2008 - 09:48 PM
1380 block and pistons, stage 3 head 286cam 1.5 roller rockers then and after a fair amount of manifold bending.
Mount the eaton supercharger where the alternator is currently but rotate the supercharger unit 180 degrees so that the outlet to the supercharger is pointing upwards create a manifold to the back of the webber on a standard manifold (so forcing air through the carb rather than sucking it through ala jonspeed / minispeed conversion) also mount an intercooler on the supercharger inlet and upgrade the pulley size to a 9psi at this point mount the alternator at the top back of the engine bay near the wiper motor simlar to air con systems.
anyone tried this and had any luck or any better ideas to make an M45 blow through
thanks
andy
Posted 04 June 2008 - 09:56 PM
might aswell turbo at that price.
Posted 04 June 2008 - 10:16 PM
How do you dump the off throttle pressure? The charger will produce a lot more flow comming off throttle than a turbo will, so a turbo dump valve is not sufficient.
You'd have to get hold of a weber off something like a lotus esprit turbo as the seals are different on a presurised carb.
Again if you go to that much cost and effort then a turbo is probably a better option.
Posted 04 June 2008 - 10:50 PM
Posted 05 June 2008 - 11:49 AM
As regards cost just need a supercharger i can mandrel bend the pipework at work and have a cpl of intercoolers knocking about, will also need a blow off valve too suit though any ideas appreciated
Posted 05 June 2008 - 12:00 PM
Is what you call a "Dump Valve" also referred to as a "Waste Gate" on a Turbo?
The Eaton Twisted Vane Roots-Style Supercharger does not have a traditional waste gate. On a turbo, the turbo still generates boost off of momentum. A supercharger is geared to the engine, and it's revs remain in sync with the engine at all times, unless the belt slips. So, most of the time, it does not generate excessive boost.
When downshifting and heavily engine braking, the supercharger will deliver more air than the engine needs, and to this effect, the Eaton supercharger opens a little flap and feeds the boosted airpressure back into the intake of the blower. That way you're not compressing extra air, just to waste it. By feeding excess air into the blower, your only penalty is driveline resistance, and not actually the air pump resistance - or at least not much. Pretty cool really, but probably does not make the cool sound you like.
The Eaton website has details. Sorry, don't remember the URL.
Posted 05 June 2008 - 01:27 PM
basicly in order to use a dump valve type thing you would need a super charger with a clutch to disenguage the rotors.
Posted 05 June 2008 - 02:13 PM
cant understand why i would need one over the jonspeed suck through system doing the same thing also the shorrock system doesnt use one or the opcom neither have a dump valve in the kit so why if i do it this way do i need one (not being flippent i just dont understand them egnough to say i understand)
Posted 06 June 2008 - 07:38 AM
The IC needs to be after the SC otherwise it'll do bugger all.
Not sure about your thought of under bonnet temps either, SCs produce plenty of heat too.
Posted 06 June 2008 - 01:23 PM
Posted 06 June 2008 - 03:48 PM
You're best asking here for more information as bypass valve upgrades is something some of the new MINI owners are having to consider when going over 230 BHP.
http://www.mini2.com...vetrain-tuning/
Just spoken to 1320 Autos, a New MINI tuning specialist, Chris there reckons if you used the Metro Turbo carb, fuel pressure regualtor and pump you should be fine with a turbo dump valve. Failing that, a bypass valve can be fitted, but would involve inlet manifold modification and obviously the related extra pipework in the engine bay could potentially be a problem.
Edited by nurseholliday, 06 June 2008 - 04:00 PM.
Posted 06 June 2008 - 05:14 PM
edit
found a pic to show how it is on the bini (part number 22)
Edited by In-a-mini, 06 June 2008 - 06:28 PM.
Posted 06 June 2008 - 06:41 PM
Posted 06 June 2008 - 06:51 PM
Posted 07 June 2008 - 08:41 AM
