"lights Left On" Alarm/reminder
20 replies to this topic
#1 Juju
Juju
  • 3,620 posts
Posted 13 October 2008 - 07:57 AM
Model:
Matilda.
Year:
2000
Faulty brain of owner means that lights are left on despite parking "nose out" in car park.
Morning all.
I was wondering if there is a way to wire in an alarm or warning light that will remind me when I have left Matilda's lights on?
Despite parking "face out" everyday so I see her lights when I leave the car park, I hadn't noticed her sidelights were still on again this morning. :thumbsup:
The whole site at work now knows the name & reg of my mini because emails & phonecalls have repeatedly been sent out about her lights being on. It's humiliating having a brain like mine & I need a little reminder to turn her lights off. Could I wire in something that goes "Hoooooooonk!" if I try & leave her with her lights on? If so, how? :P
Dr Cheese-Head
^_^
Edited by Juju, 13 October 2008 - 07:57 AM.
#2 GraemeC
GraemeC
  • 7,440 posts
Posted 13 October 2008 - 09:22 AM
ebay item number 110297675289
Cheap and local!!
#3 Jupitus
Jupitus
  • 1,479 posts
  • Local Club: Breathemini
Posted 13 October 2008 - 09:24 AM
Model:
Matilda.
Year:
2000
Morning all.
Dr Cheese-Head
^_^
Custom solutions wouldn't be very hard to do, but off the shelf these chaps do one...
http://www.vehicle-w...lays/timers.php
#4 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 13 October 2008 - 09:44 AM
Juju,
Presuming your interior ligth and therefore your door switches work, you could take a feed of this, to feed power to a relay.
Then connect the power from the dashboard or tail lights to switch the relay. Add an earth, and a buzzer, and jobs a good 'un.
You can get the relay from anywhere, even Halfords, but not sure where to find a buzzer...
Dave
#5 Waffs1984
Waffs1984
  • 437 posts
Posted 13 October 2008 - 09:57 AM
Dave
Maplin...
#6 Juju
Juju
  • 3,620 posts
Posted 13 October 2008 - 10:08 AM
Dave
Maplin...
Lordy be. Thassall a bit complicated. Ta anyway.
Just found this at Wilco and apparently Maplin used to do a whole kit that some geezer fitted to his MG.
I'll speak to the Wilco peeps. If the alarm comes with wiring diagram & destructions then I might have a go myself. Otherwise it's "batting eyelashes time". :thumbsup:
#7 Jupitus
Jupitus
  • 1,479 posts
Posted 13 October 2008 - 10:21 AM
Dave
Maplin...
Bear in mind that the Wilco one sounds if lights are on but igntion off, which is functional but might be annoying in some circumstances. The Maplins kit is just that, a kit of electronic components almost as a hobby project for people to put together, so soldering skills would be required.
The item on ebay or the one I linked would not be difficult to fit ... a scan of the instructions that come with and people here would be easily able to walk you through it.... ^_^
#8 Jupitus
Jupitus
  • 1,479 posts
Posted 13 October 2008 - 10:48 AM
Juju,
Dave
I thought this through and it is quite simple, yes.
Buzzer here:
http://www.maplin.co...x?ModuleNo=3213
for £1.99 plus a standard automobile relay. Power into relay from Red/Green sidelights circuit, trigger into relay from interior light circuit means 'IF door=open AND lights=on THEN buzzing sound'. Not too difficult at all!
#9 Ethel
  • 26,073 posts
Posted 13 October 2008 - 11:15 AM
Since the interior light just switches to earth you may get away without the relay. May be a LED would add an extra warning and improve a relayless circuit?
You could also add a relay to make the lights ignition dependent, with a bypass switch should you ever need them to work sans key.
#10 998dave
998dave
  • 4,566 posts
  • Name: Dave
Posted 13 October 2008 - 11:35 AM
Putting a buzzer in parallel with the interior light, power from the dash board lights, and earthing through the interior light door open switches.
That'd be £1.99 for a buzzer and nothing else then? well, a couple of connectors maybe.
Bring a couple of screwdrivers and some wire and I'll do it... :thumbsup:)
#11 Juju
Juju
  • 3,620 posts
Posted 13 October 2008 - 11:51 AM
Bring a couple of screwdrivers and some wire and I'll do it... :P)
Dave - where are you? I might take you up on that, please, now that those combined replies have confused me completely. :thumbsup: :rolleyes:
Ethel - reply to your PMs, rude boy. ^_^
#12 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 13 October 2008 - 12:02 PM
Thats what I did, i got a cheap 12v buzzer, connected negative to door switch and posotive to the sidelight circuit, open door with lights on and bzzzzzzzzzzzzz, only problem with this system is when your fumbling about in your car at night and turn your interior light on you get a very annoying buzzing sound. But i put up with this for the sake of being able to start my car.
#13 Ethel
  • 26,073 posts
Posted 13 October 2008 - 12:16 PM
I did wonder if the buzzer would reverse flow, where did you tap into the light switch? A diode (LED) may sort that out.
#14 998dave
998dave
  • 4,566 posts
  • Name: Dave
Posted 14 October 2008 - 09:39 AM
Dave - where are you? I might take you up on that, please, now that those combined replies have confused me completely. :D :D
Ethel - reply to your PMs, rude boy. :wub:
East London,
Pm for more details, would rather not publish my address all over the web...
If you do want me to look at it next week let me know and I'll make sure I've got my multimeter and a few bits and pieces to hook it up with.
Dave
#15 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 14 October 2008 - 10:02 AM
Bring a couple of screwdrivers and some wire and I'll do it... :D)
The buzzer does back flow leaving the interior lamp on dimly, flatttening your battery, a diode in the power side before the buzzer works nicely, early metros had one fitted near the fusebox with a standard lucas terminal on each end, no idea what it's for but i've scrapped enough of them to find it each time!!
