Rokee Dash?
6 replies to this topic
#1 beaubrad
beaubrad
  • 736 posts
Posted 17 October 2008 - 09:30 AM
i have got myself a rokee dash and wanted to give my mini the Mk1 look, but i was just wondering if i have to take the bottom rail plastic off as the metal behind it is about 1inch inwards (sorry hope you understand this????)
#2 Retro_10s
Retro_10s
    Moderator
  • 10,186 posts
Posted 17 October 2008 - 09:52 AM
Moved Topic to correct section.
#3 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 17 October 2008 - 11:54 AM
quick answer to your question..... YES! :thumbsup:
#4 bert998
bert998
  • 2,558 posts
Posted 17 October 2008 - 12:02 PM
I have had a rokee dash with the lower dash rail padding fitted.
#5 beaubrad
beaubrad
  • 736 posts
Posted 17 October 2008 - 12:46 PM
ok cheers . . .but what do i have to do to make the switches go back in there place as they are held by 2 brackets ??
#6 jonbouy
jonbouy
    Starting My Mini Up
  • 1 posts
Posted 29 October 2008 - 03:37 PM
To Beaubrad,
Re MkI style Rokee dashboard.
You don't normally need to remove the lower padded rail, but it's best to remove the chrome strip along the top back edge. You can do this by holding a block of wood against it and gently tapping this with a hammer. Work your way along the edge and gradually remove it.
In the original kit there would have been a plastic covered foam strip to fit below the centre panel, long enough to span the distance between the two side panels and approx. 1¼" x ¼". This was to fill the gap between the centre panel and the parcel shelf. (The gap varied greatly from car to car).
I don't know quite how this works, but I have tried to attach a picture of the completed installation. If you cannot open it, send me your email address to johnyardy@talktalk.net and I will send it as a jpeg file via normal email.
best of luck, John Yardy.
#7 beaubrad
beaubrad
  • 736 posts
Posted 29 October 2008 - 03:40 PM
To Beaubrad,
cheers mate ,
