Jonspeed Supercharger Kits / Boost
22 replies to this topic
#16 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 23 October 2008 - 05:30 PM
your best and only option imo is to get the timing and fuelling set up properly on a rolling road by someone who knows what they're doing.
maybe you might listen the 3rd time we tell you....
#17 topwaxer
topwaxer
  • 73 posts
  • Local Club: spamfritter mini club
Posted 23 October 2008 - 06:03 PM
Maybe i should have explained.
The car is currently in the garage and has had a rebuilt engine and has been on the rolling road however its pinking with the compression ratio of 8.5-1.
I was kind of hoping that other people might be able to pass on their expertise or past knowledge with this to kit try and help me / the garage solve the problem.
#18 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 23 October 2008 - 08:00 PM
whats the boost gauge saying its running?
whats the igntion advance and timing set to?
whats the AFR showing?
what garage is it being rolling roaded at?
I run 15psi on 8.7:1 and will be running 20psi on the same CR, it doesn't pink as i set the ignition timing and fueling myself then just pop to the rollers for a power run.
#19 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 23 October 2008 - 10:31 PM
Providing the fuelling is spot on, you can either drop the compression, retard the timing, lower the boost or a combination of the above.
#20 topwaxer
topwaxer
  • 73 posts
Posted 25 October 2008 - 10:32 AM
thanks for your help i will let you know how i get on.
once again thank you
#21 jimbo1234567
jimbo1234567
  • 12 posts
  • Local Club: na
Posted 26 October 2008 - 10:20 PM
if you want my advice buy the david vizard book(the big yellow one) all will be explained if you read the forced induction chapter and the ignition system chapter, i wish i did 15 years ago when i first turbo,d my clubman, it wouldnt have melted after 50 miles.
#22 Wil_h
Wil_h
  • 3,244 posts
Posted 27 October 2008 - 02:20 PM
Personally the yellow book is useless for turbo advice.
best to buy a proper turbo book if you want to know about charging.
search for Corky Bell.
#23 topwaxer
topwaxer
  • 73 posts
Posted 08 November 2008 - 09:37 PM
I have an update to this saga lol
Now have the car back from the garage and it is set up to run in the engine as its just been rebuilt. However as with my mini there are a few problems
1. The clutch is sliping on the rollers when showing about 45h at the wheels (its a standard verto 180 mm clutch) s was wondering what my options are with this, pre verto or is there anything else i can fit to help.
2. The car is only running 5 degrees advance on the standard dizzy and is heating up at idle to about 3/4 of the way up the temp gauge. I have a super cool 2 core radiator fitted so what would be the best options to aid cooling ? Do i need the dizzys advance curve altering( it has a standard cam) would an oil cooler help
