Yes I have searched this forum as well as many others. That being said...
I have a 1997 Japan spec spi with ac / air conditioning and an mpi block etc.
I imported it not too long ago and have spent hours fixing issues. I have gone through and replaced all the vacuum lines, the lambda or o2 sensor, plugs, distributor cap / dizzy, wires, reset the ecu / computer, cleaned the butterfly / throttle, and have obviously changed the oil. Oh and I have also changed the oil pressure sensor but with the wrong type so the dummy light comes on fairly regularly.
Ok, after I just replaced the vacuum lines and lambda it solved a bucking problem I had at highway speeds. However now when I accelerate the engine pauses then smoothly accelerates. It feels like a hesitation or delay right after I press the gas pedal. Happens at all speeds even from a dead stop. Feels like it would die or stall if I pressed the gas to the floor from a dead stop and a buck if I were to press it from any moving speed.
Any suggestions?
Thanks!
-Paul
Hesitation On Acceleration
antichristpm
, Oct 19 2008 08:17 AM
5 replies to this topic
Posted 19 October 2008 - 08:17 AM
Posted 20 October 2008 - 08:54 AM
I spent ages trying and replacing things on my 1994 spi with no luck and a friend who is a pro mech spent a lot of time on his (ex) girlfreinds cooper 35 spi also ,so i think thats how they are i'm afraid sorry.
Posted 20 October 2008 - 09:06 AM
the mixture bein set correct??? timing slightly out??? maby theres two much air and fuel gettin to the engine?
any of that help???
any of that help???
any of that help???
any of that help???
Posted 20 October 2008 - 06:21 PM
Bahhh,
I spent another hour searching forums and decided to double-check my own work again.
I found that the vacuum line I made was a wee bit too short from the back of the manifold to the MAP sensor. It had a pinch on the end that went to the MAP. I replaced it with a longer line with no pinches and presto! Problem gone!
Thank you for your replies and I have to thank the forums for help too!
Posted 20 October 2008 - 06:25 PM
woo nice one. all runnin good????
glad it was summink simple???
x
x
