Injecting A 998
Posted 19 October 2008 - 08:09 PM
I am still to finalise what parts would be necessary to do this.
I have made a list of parts that I think I will need but just need a shove in the right direction to be honest.
SPI cam
Injection setup manifold etc.
SPI tank (preferably)
Rover MEMS ECU
Would it be easier to acquire a loom from an SPI and would I be able to keep the existing 998 head?
Is there anything else that I have blatantly missed?
Posted 19 October 2008 - 08:20 PM
Posted 19 October 2008 - 08:25 PM
Posted 19 October 2008 - 08:29 PM
Posted 19 October 2008 - 08:32 PM
Don't forget you will need all the MPI parts which the plastic throttle body is naff, it doesn't incorporate a stepper motor so you have to fit a PWM idle valve in an ideal situation that is what I would like to do but I can't just justify the expense if that all makes sense.
Posted 19 October 2008 - 08:34 PM
that system, can it be used on say a 1380? or is it 998 only (i read the article in miniworld where they showed you how to install it)
As it is a mappable ignition and fueling system it will work with any a-series engine regardless of the cubic capacity, you will just need the correct map which in theory shouldn't be too hard to obtain.
Posted 19 October 2008 - 08:36 PM
Best talk more about it to them if your interested.
Posted 19 October 2008 - 08:38 PM
Posted 19 October 2008 - 08:45 PM
Posted 19 October 2008 - 09:16 PM
Have a good look around the site, I believe they are claiming around 140+bhp from a 1380
johngreenclubby-Oct 19th 2008
Hi, yes they are claiming 140bhp from a injected 1380, its running on bike throttle bodies on a home made manifold, with the Canems ECU, it was tested on the same rollers as previously when the ignition only ECU was being used, and showed a 6hp gain at the top end, BUT a massive gain of 14+ HP&torque at 5250rpm. It was also run on the track at Elvington on a sprint in August 08 & set a new class record with ignition only ECU and then run again in September 08 on the same track and set another class record by almost a full second! Not only once did it beat the previous record but 5 times out of 6 runs.
How do I know all this? it is my car! Everybody says that you can`t get big power from injection on a 5 port head, look on www.canems.co.uk for the full spec and video etc
Posted 19 October 2008 - 09:21 PM
Posted 19 October 2008 - 09:29 PM
It does sound very impressive, I can't help but think the SPI setup will be far more forgiving, unless I require an SPI head which requires engine out block pocketed hmmm although perhaps easier, the costs will work out the same?
I shall have to do some maths me thinks.
