Speedo Not Working
Posted 22 October 2008 - 11:05 PM
I changed from a auto 998 to a manual metro 1275 and now my speedo is not working. Yes it worked before the engine change and it is hooked up also made sure it didnt come loose from the speedo. Any ideas on what else to check?
Posted 23 October 2008 - 08:43 AM
also check the speedo cable connection at the gearbox end, make sure it's correctly seated...
This can be done by removing the speedo end of the cable and turning, if it dow turn then it's not located... alternatively drive along with it disconnected and where you can see it, and you should see it rotating..
FYI..
When I supply a gearbox there are no speedo drives in there, unless specifically asked for, basically because if I put them in I have no idea that they are going to be the correct ones for the application... so saves the return questions 'my speedo does not read correctly'
Edited by GuessWorks.co.uk, 23 October 2008 - 08:45 AM.
Posted 23 October 2008 - 09:30 AM
did the new gearbox have speedo drives in it ?
How would i check? I got the engine and gearbox as one unit and put it in the car. I dont know what to look for.
Posted 23 October 2008 - 04:56 PM
Posted 23 October 2008 - 05:01 PM
remove cable, undo 1 securing bolt and fork thingy, remove cover and there should be one of the spindles.
the other spindle you need to remove the radiator, and the engine mount, and its mounted behind a small plate with 2 bolts.
you can also check to see if there is a drive by turning the speedo cable youself between your fingers, if it turns several turns (not just a bit then goes stiff) then your missing 1 or 2 of the spindles.
Posted 23 October 2008 - 10:32 PM
Posted 24 October 2008 - 07:46 PM
where can you buy these and if there are a few out there which one would i get for a 1275 metro engine running on 12 inch tires?
i got mine from minispeed last time, but you may be able to put up a wanted add on the forums once you know what number teeth spindles you need (depends on your Diff ratio)
Posted 25 October 2008 - 07:31 AM
Posted 25 October 2008 - 05:17 PM
I have pretty much all of them
or you can get them from guessworks
Posted 27 October 2008 - 12:56 PM
Posted 27 October 2008 - 01:03 PM
Posted 02 December 2008 - 11:47 AM
No, auto drives are completely different
Hello,
me again. How many different spindles are there out there? if there is only a few options out there and you have most/all of them how much for one of each? I know it sounds crazy but if the price sounds good i may get them all and them sell off the ones i don't need.
