Track Rod End Pin Thread?
23 replies to this topic
#16 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 16 January 2014 - 11:47 PM
It will be different for every individual track rod end, or at the very least every manufacturing batch of them. No idea in Belgium but in the UK it's not particularly expensive.
#17 Dusky
Dusky
  • 5,322 posts
Posted 17 January 2014 - 06:27 AM
They dont even sell them here I think :P Always buying on minisport :P So if anyone knows how many times I need to spin the minisport ones it would be very helpfull:) otherwise I'll be going to let them tracked when the engine is back in:p
#18 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 17 January 2014 - 08:46 AM
  I was referring to the price of tracking, rather than the price of a TRE, as that's what you asked!
#19 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 17 January 2014 - 11:39 AM
As Dan has pointed out, the t.r.e may be of differing length to the original. Therefore for the same amount of turns you could have the t.r.e pin a different distance from the end of the track rod.
Plenty of threads about doing your own tracking if you want to give it a go.
Edited by jime17, 17 January 2014 - 11:40 AM.
#20 Dusky
Dusky
  • 5,322 posts
Posted 17 January 2014 - 03:36 PM
Oh yeah, sorry mate :P Was early in the morning! ;)
I'll give it a go myself untill I can go to the guy who does it professionally. So I can atleast drive there :P
#21 tiger99
tiger99
  • 8,584 posts
Posted 19 January 2014 - 06:20 AM
By the way, if you have a lot of negative camber, you need longer TREs to get sufficient thread engagemengt to be safe, and the part you want, a Herald/Spitfire/Vitesse/GT6 TRE, is usually slightly cheaper from Triumph suppliers than Mini suppliers, because it is a standard part as far as they are concerned, not a special. Hopefully that info will save someone a quid or so....
#22 Dusky
Dusky
  • 5,322 posts
Posted 19 January 2014 - 08:14 AM
I dont really know about my camber etc.. The mini is standard( only a tweaked engine) dont know if the camber changes over time?
#23 tiger99
tiger99
  • 8,584 posts
Posted 19 January 2014 - 08:34 AM
No, only if you have fitted negative camber lower arms, so you will just be using standard Mini TREs.
#24 icklemini
icklemini
  • 2,982 posts
Posted 19 January 2014 - 09:40 AM
Needs tracking. .. about £25...
Edited by icklemini, 19 January 2014 - 09:41 AM.
