I had brand new Yoko A539's fitted to the front, back in March this year. At the same time i had new ball joints and wheel bearings.The Tyres have excessively worn on the inside tread, so bad that there actually bald.
My tyres always go like this and usually only last 15 months, but 6 months is ridiculous. The garage informed me that worn ball joints were causing the tyre wear problem hence i had the ball joints done. It seems to have made the problem 10X worse. Oh and the wheel bearing on the drivers side have gone again. (I've gone through 5 set of front wheel bearings in 4 years).
My tyre pressure's are normal and correct.
The only thing i've noticed is the top of the drivers wheel is angled inwards slightly, make the bottom edge go slightly out. Would this be due to incorrect adjustment of the tie rods?
Would appreciate anyone's advice.
Edited by Minitrio, 30 October 2008 - 10:07 PM.
