Need help! Runs hot, slow for a 1275!
Posted 17 July 2005 - 09:12 PM
I have had the car for about a month now and it just seems slow for a 1275. The car runs between N and H and creeps closer to H the longer the car runs. My fiance, who has a 1977 1340 Leyland Mini has adjusted the mixture, cleaned the carb, checked all the wiring...everything in the Haynes that he can think of!
There aren't many specialists here in the US (driveable distance anyway), the one closest to us has looked over the car and visually checked the timing and everything else...couldn't quite figure it out. He said to replace the carb but another specialist told us it was fine. We don't know what to do. My fiance is very handy and does most of the work himself...so any suggestions are greatly appreciated!
Note - if you look at the engine from left to right the #3 cylinder spark plug at idle runs better when it is disconnected. The car has an HIF carb. The engine does not sound normal until it gets to a higher RPM...where it sounds fine. Thank you!
Posted 17 July 2005 - 09:26 PM
the car looks very nice hope you get it sorted
Posted 17 July 2005 - 09:30 PM
Additional note...
I have electronic ignition and he has points.
Thanks so much for the suggestion!
Posted 17 July 2005 - 09:31 PM
ahh, this is the problem......everything in the Haynes that he can think of!
hehe seriously though, the temperature and humididty you get there is prety imence for a little mini, and a 1275 engien needs all the cooling it can get, i would chage the hoses and flush the rad and all the engine, i would check your water daily, then you know its not that. also, check if there is a thermostat in there, if not i would buy one!
Posted 17 July 2005 - 09:36 PM
Posted 17 July 2005 - 09:39 PM
Posted 17 July 2005 - 09:47 PM
Posted 17 July 2005 - 09:48 PM
Posted 17 July 2005 - 09:57 PM
Posted 17 July 2005 - 10:31 PM
Posted 17 July 2005 - 11:59 PM
Posted 18 July 2005 - 12:18 AM
Posted 18 July 2005 - 11:40 AM
If you are going to use a new rad, then use the two core rather than the four core. Definitely use the six blade fan and the correct thermostat and carb needle for your location but in general high ambient temperatures shouldn't be a problem for a Mini.
Cambridgeshire Classics are a good company, and if they were designing this car to be sent to Florida I would expect them to have fitted it out correctly with all the right parts.
Posted 18 July 2005 - 03:00 PM
By the way- Im her mechanic/fiance/cook/lover
Thanks for all of the help!!
Posted 18 July 2005 - 03:51 PM
Can you tell the origins of the engine, as I doubt it's of mini origin, does it have an engine number, and what sort of octane fuel are you using ?
