Need help! Runs hot, slow for a 1275!
#46
Posted 28 July 2005 - 11:06 PM
#47
Posted 28 July 2005 - 11:09 PM
:saywhat:It spewed out icky stuff on my windshield on my way home from work and was running between N and H. Replacing the head gasket tomorrow!
#48
Posted 29 July 2005 - 04:37 PM
#49
Posted 29 July 2005 - 07:10 PM
#50
Posted 01 August 2005 - 11:26 PM
#51
Posted 02 August 2005 - 09:39 PM
If not, I can't think what it is. I assume you changed the oil when you did the head gasket?
#52
Posted 02 August 2005 - 10:00 PM
Does it squirt once in a while or all the time. If its all the time, Leaky chaffed hose??????????? Or gasket. I presume you have replaced the rad so there should be no leaks there. If its only once in a while then its likely to be what Dan said, the overflow on the rad neck is not being discharged below the car. There is a metal hoop inside the rad just under the cap, the coolant should just be level with this when the engine is cold, any more and it will spew it out as the coolant expands. Oh and is the rad cap up to the job, rusty spring, perished seal????????The car is running much better now, the temp gauge goes a little over N but not to halfway between N and H. BUT sometimes antifreeze does shoot out of the engine compartment and onto my windshield. Could it be that there is just too much antifreeze in the radiator and when it gets to a certain temp it comes out the overflow?
Glad to hear you're getting to the bottom of the problem
#53
Posted 03 August 2005 - 01:06 AM
