Mpi Ecu
Posted 03 November 2008 - 01:11 AM
//Sam
Posted 03 November 2008 - 11:03 PM
Hope that helps!
Posted 03 November 2008 - 11:11 PM
i also noticed this on ebay a few mins ago.. is it worth getting?
http://cgi.ebay.co.u...O...A1|240:1308
Posted 04 November 2008 - 11:47 PM
thanks for the reply but what do you need or is involved in over chipping the ecu
That looks like Bini stuff not Mini - follow link for icon race Superchip on Fleabay..
http://cgi.ebay.co.u...e...A1|240:1318
Posted 05 November 2008 - 12:43 AM
thanks il keep an eye on that
Guest_iansmini_*
Posted 05 November 2008 - 01:16 AM
Really for what the ECU is it is very good as standard up to 100bhp as you mod the carp out of your engine, then you should look at metro turbo, canems, emerald ECUs.
I do believe personally mappable fueling and ignition systems are the way to go.
However think about it what is the point of say breaking down the queens door only to find no gold, that is pretty much what "chipping an ECU* is unlocking potential that isn't there.
Posted 05 November 2008 - 04:27 PM
Standard MPi ECU is not re-mappable so don't believe anything you read to the contrary on eBay. The MPi ECU was programmed, I believe, using a unique language that Rover/BMW developed and never released to the general public, so nobody, as far as I am aware have been able to develop a re-mapping tool.
You'd be very very lucky to get 100 bhp out of a standard ECU. Mid 80's should be easily reachable, and at a push, 90. But you have to do some serious mods to get there and it'll start getting very expensive.
Posted 05 November 2008 - 04:52 PM
The Metro Turbo ECU is only a boost modulator, they still used a carb.
Posted 05 November 2008 - 07:32 PM
will be along with 3.44 fd, maybe sc drops, 4 pin diff.
if its not 100bhp, it should have a nice torque curve.
Posted 06 November 2008 - 08:57 AM
http://www.theminifo...x...c=79995&hl=
The way the MPi works its unlikley to get to 100 horses....... the SPi is the injection Mini for tuning
Hope this helps
Rob
Posted 06 November 2008 - 11:21 AM
Posted 06 November 2008 - 11:25 AM
Posted 07 November 2008 - 09:15 PM
i reccon you could get somehwere near 100bhp running standard ecu.1380 rebore, swiftune cam, cooper works head, 1.5 roller rockers, lighened/balenced flywheel. decent exhaust system. gas flowed inlet manifold, larger throttle body. this is what me and my dad are looking to put together for his car.
If you're going to do that level of mods and invest that much dosh, you may as well go the whole hog and buy an Emmerald ECU to go with it, and release the extra horses the standard ECU is holding back.
Seriously though, for a much more fun drive with minimal hassel, just get a 90bhp / Stage 3 kit from Mini Sport or similar, or spend a tad more and get an Ex-JCG Conversion done. It'd probably be more than enough and whoever you get one from can probably fit it for you too.
If off-the-line poke is also an issue for you, then see about changing the diff in your box too. There's an excellent article in this months Mini Mag explaining about diff conversions.
Posted 11 November 2008 - 05:17 PM
Posted 11 November 2008 - 06:47 PM
You will be limited to circa 90 bhp with the standard ECU even with the Superchips Race ICON, it only alters the ignition, has no effect on fueling.
Its all very complicated and no one has come up with a truely workable answer to the factory fit injection systems. The Megasquirt option fell on its arse, requiring more work. I'm not saying that it wont work, just that its not working , yet!
For the ultimate injection system, bin the MPI manifold, build a custom manifold with the injectors further back near the throttle bodies, and use any programable ECU you want
