my mpis exhaust has seem to dropped at the manifold end ,theres a metal mesh bit between the manifold
and cat converter and its started to frey,anyone had this problem, my dad has put a bolt through the floor
and put a hook round the exhaust to hold it up another couple of inches,it seemed to have worked just got a nice bolt on the floor
which you can see!!! but gonna get a centre console anyway, so dont really matter. cheers moz
Exhaust!
minimoz
, Nov 05 2008 07:40 AM
1 reply to this topic
Posted 05 November 2008 - 07:40 AM
Posted 05 November 2008 - 09:18 AM
If something isnt right chances are somethings causing it ....lol. for starters Id check your engine steady bars at top left, as you look at it, connected to block and back to bulkhead and underneath from gearbox to front subframe. Then check your subframe mountings at the back and the teardrops at the front. By putting a bolt in you may cure the problem but endup with a hole in the floor where the bolt pulls through later cause you didnt find the root of the problem. If the exhaust was ok before and is now too low.......something has failed to let it drop.
Rob
Rob
