Mini Engine Swap
26 replies to this topic
#16 Asphalt
Asphalt
  • 2,173 posts
Posted 14 November 2008 - 12:30 PM
And use the SPI's complete cooling system!!
1275cc A+ engines don't have a bypass between head & pump.
The 998's cooling siystem doesn't work sufficiently without that bypass.
(The SPI uses a different bypass)
For the starter conversion, look here:
http://www.theminifo...x...t&p=1212737
There's no need to alter the complete wiring :D
Regards,
Jan
Edited by Asphalt, 14 November 2008 - 12:31 PM.
#17 s storer
s storer
  • 46 posts
Posted 14 November 2008 - 01:08 PM
Regards,
Jan
thanks it's great to good clear advice. cheers simon
#18 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 14 November 2008 - 01:15 PM
and finally, if you haven't already... upgrade your brakes to disks....
#19 s storer
s storer
  • 46 posts
Posted 14 November 2008 - 01:44 PM
thanks i'm going to use the cooper's brakes.
#20 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 14 November 2008 - 02:09 PM
one other question...
What sort of gearchange does the clubman have remote or rod ?
#21 s storer
s storer
  • 46 posts
Posted 14 November 2008 - 05:17 PM
What sort of gearchange does the clubman have remote or rod ? don't know it's the original 1970 engine. will this make a difference.
#22 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 14 November 2008 - 05:19 PM
may do, as it'll be a bit of a fiddle putting the rod change gear change in if it's a remote currently...
#23 s storer
s storer
  • 46 posts
Posted 14 November 2008 - 05:28 PM
thanks i'll look into that,
#24 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 14 November 2008 - 05:54 PM
as i said easyer fixing the 998
#25 s storer
s storer
  • 46 posts
Posted 14 November 2008 - 05:58 PM
Thanks but i think i'll still use the 1275 and all the ancillaries i should be able to get hold of the bits i need to do the conversion.
#26 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 14 November 2008 - 06:16 PM
sure I would add up the costs, what do I want it for, how much can i do myself. you did say you had little knowledge i would bear that in mine as well. not that you start and after a few mishaps give up and be weed off.
#27 s storer
s storer
  • 46 posts
Posted 15 November 2008 - 01:46 PM
Spoke to a old friend yesterday, he's worked and had loads in the past, and would love the chance to do the job, i shall work with him and try and pickup and much knowhow as possible. know i know it's possible i'm think i will go over the clubby shell strip it down and get a full respray done get it looking it's best and go from there. cheers.
