Spi Still Will Not Start When Cold
Posted 13 November 2008 - 06:12 PM
cheers.
Posted 13 November 2008 - 07:49 PM
Posted 13 November 2008 - 08:01 PM
cheers thanks for that i will have a look someone else said the same as you so i think i will start there.Prob a fault with the coolant temp sensor under the inlet manifold or check the wiring to it as it can wear through on the inlet manifold and bulkhead,this could give the ecu a false reading and poor cold starting,high emmissions etc
Posted 13 November 2008 - 09:36 PM
Hi, You emailed me, (the old git), however for months I have not been able to get on the site because it would not accept mypassword. Sooooo tonight I've changed myself to Racing Gold, our race colour for next year. Answer is same as above. Did one last week, same symptons. Unscrewed sensor underneath inlet manifold and replaced it. Started sraight away, no probs sincecheers thanks for that i will have a look someone else said the same as you so i think i will start there.Prob a fault with the coolant temp sensor under the inlet manifold or check the wiring to it as it can wear through on the inlet manifold and bulkhead,this could give the ecu a false reading and poor cold starting,high emmissions etc
Posted 13 November 2008 - 11:11 PM
Cheers for that info it sounds to me from you and others this could be the problem , if it is i will let people know so hopefully it may help someone else as its a pain trying to sort these things.Hi, You emailed me, (the old git), however for months I have not been able to get on the site because it would not accept mypassword. Sooooo tonight I've changed myself to Racing Gold, our race colour for next year. Answer is same as above. Did one last week, same symptons. Unscrewed sensor underneath inlet manifold and replaced it. Started sraight away, no probs sincecheers thanks for that i will have a look someone else said the same as you so i think i will start there.Prob a fault with the coolant temp sensor under the inlet manifold or check the wiring to it as it can wear through on the inlet manifold and bulkhead,this could give the ecu a false reading and poor cold starting,high emmissions etc
Posted 14 November 2008 - 12:55 PM
Posted 18 November 2008 - 01:15 PM
I've had the same problems with my SPi in the past, coolant temp sensor changed and all fixed!
