1972 Mpi Woody
#46
Posted 05 July 2009 - 08:28 PM
Will it be ready for the IMM - see you there
#47
Posted 06 July 2009 - 09:33 PM
done some more work on it. got loom in and put engine and front sub frame in tonight.
not sure if it will be at imm yet stil have loads to do.
#48
Posted 09 July 2009 - 10:36 PM
also recovered the clubman estate rear seat with cover from mpi mini seat.
anyone know where i cane get some light stone vinly trim to cover my door cards???
#49
Posted 13 July 2009 - 05:04 PM
Davy
Edited by scottish minivanman, 13 July 2009 - 05:09 PM.
#50
Posted 13 July 2009 - 05:07 PM
That rear seat looks awesome, I'll try that out with my rear seat using the "Cooper" unteriot I've got
Davy
#51
Pretty cool Penny-farthing too
#52
Posted 25 July 2009 - 04:56 PM
MPI ENGINE FITTED WITH SIDE MOUNTED RADIATOR.I HAD TO USE A SPI THERMOSTAT HOUSING AND MOVE THE TEMP SENSOR TO THE CYLINDER HEAD BECAUSE COOLING THE FAN HIT IT.THIS HAD TO BE DRILLED AND TAPPED TO GET IT TO FIT.
NOT SURE WHAT BADGE TO USE
GOT SOME MORE WORK DONE.ENGINE IS NOW RUNNING.WILL TRY AND FINISH IT AND HAVE IT MOTD THIS WEEK
Edited by M1N1 MAN, 25 July 2009 - 05:05 PM.
#53
Posted 25 July 2009 - 05:46 PM
#54
Posted 26 July 2009 - 11:29 PM
im getting all the door cards and trim made now by newton commercial have already had the cab carpet. should get it week monday.This looks great. I had forgot about this project. In answer to you question about covering the door cards. Isnt their a fabric shop near you. They should have some stuff.
side windows fitted
seats and dash fitted
front mpi screen fitted
#55
Posted 27 July 2009 - 08:44 AM
Where did you get the seat covers from? And why did you change from a front mounted radiator to side mount?
#56
Posted 27 July 2009 - 01:55 PM
#57
Posted 27 July 2009 - 05:37 PM
i took the seat covers off the mpi mini saloon back seat and covered the estate one with it.to fit the front mount rad you really need to fit the mpi front panel whitch is cut around rad and fan.with that panel fitted when you put a mk1 grill on you can see the cut out part of the panel.Very nice!!!!! Really love it...
should have it tested end of week or next monday! all going well it should be at imm.This is lush. Got the MOT booked yet and will you be coming to the IMM I want to have a closer look at this.
#58
Posted 27 July 2009 - 06:05 PM
#59
Posted 30 July 2009 - 11:26 PM
