Tyre Pressure
minipixie
, Jul 21 2005 07:43 PM
20 replies to this topic
Posted 21 July 2005 - 07:43 PM
How can/do I find out how much my tyre pressure is/should be? Pretty Pwease
They look a ickle low/flat!
Cheers, Sian
Cheers, Sian
Posted 21 July 2005 - 07:49 PM
it fully depends on the car but the haynes says 2 bar=29 psi so it should be around that. Im sure other members run all sorts of pressures it has been talked about before and there was quite a difference
Posted 21 July 2005 - 07:50 PM
well, your running 12's from the pic so they should be at 30 psi, you can get a tool, its like a pen, you take the dust cover off and press it over where you put the pump onto and a little thing will pop out with a number and thats your tyre dresure!
Posted 21 July 2005 - 07:59 PM
Or go to your local petrol station and use the air machine...
Posted 21 July 2005 - 08:02 PM
on all my local machines they dont give pressures for mini's, plus the machine doesnt tell you the pressure its the sign next to it that does :tongue:
Posted 21 July 2005 - 08:05 PM
deary me! what station is that?, we go to shell because its free that gives you a little reading, i get confused with it though, i supose foot pumps are the best, keep you fit while you pump the tyres up, mine was a cheap one and it flopprd all over the place so i smashed it to bits! ask miniman!on all my local machines they dont give pressures for mini's, plus the machine doesnt tell you the pressure its the sign next to it that does :tongue:
Posted 21 July 2005 - 08:16 PM
well i went to the petrol station and it doesnt tell u, u can only choose the pressure u want, so i jus guessed at 30psi?? will that be ok?? do hope so, cus iv drove home now
Posted 21 July 2005 - 08:18 PM
thats what i run mine on with 6x12s
Posted 21 July 2005 - 08:20 PM
does that mean it;s too much for mine?
Posted 21 July 2005 - 08:21 PM
if you have 4 1/2 x12s then that should be ok as well
Posted 21 July 2005 - 08:24 PM
im sorry im a ickle confussled....(it doesnt take much)
what do u mean by 4 1/4 x12s ?? :fear:
Posted 21 July 2005 - 08:26 PM
Beware of petrol station air pumps ... they are unreliable ... unless you just use the pump and check the pressure with your own gauge which you know is accurate
Posted 21 July 2005 - 08:29 PM
There are not many accurate wyas of knowing your tyre pressure....
I have heard even those little gauges you press onto the valve can be about 15-20% out! If they are about 30psi then they will be fine!
The 4.5x12s is the size of your wheel, 4.5 inches thick and 12 inches diameter :wink:
Bungles are thicker than yours, 6inches thick!
Posted 21 July 2005 - 08:33 PM
aahhh im with ya now!!!! i understand!!!! sorry ya have to explain things for my ickle mind! lol!
cheers!!!
cheers!!!
I keep mine at 28!
THe user manual says 26 though.
Mine r 12".
Hope that helps a little bit minipixi
Mine r 12".
