yep.... smokin start up from a cold engine... causes please?
no smoke from a warm start or decelleration
96,000 miles young
smoke is blue
Edited by louise66, 17 November 2008 - 11:07 PM.
Posted 17 November 2008 - 11:04 PM
Posted 18 November 2008 - 09:42 AM
Posted 18 November 2008 - 05:06 PM
Valve stem seals,off with its head!
Posted 18 November 2008 - 05:08 PM
Posted 18 November 2008 - 07:10 PM
Posted 18 November 2008 - 07:20 PM
Posted 18 November 2008 - 07:21 PM
Edited by DJ T, 18 November 2008 - 07:22 PM.
Posted 18 November 2008 - 09:21 PM
Posted 19 November 2008 - 10:48 PM
Ah I see so all we need to do is stop the valves dropping in the cylinder.yes it can be done with the head on. you need a length of rope that can be pushed down the spark plug hole and an overhead valve compressor tool that is designed to compress the spring by grabbing it at the base and squeezing the spring. pull the plugs out, rotate cylinder one to the compression stroke, stick the rope in and compress it. then use the spring compressor tool to compress the spring and keep it compressed and pop the clip off the valve. pull the spring away and pry the rubber seal off. put the new rubber one on and put the spring back on with the clip. repeat for each cylinder and pair of valves.
Posted 20 November 2008 - 09:37 AM
Posted 20 November 2008 - 10:51 AM
Posted 20 November 2008 - 09:59 PM
Posted 20 November 2008 - 10:37 PM
Posted 21 November 2008 - 04:17 AM
Edited by elvisthepizzaman, 21 November 2008 - 04:19 AM.
