Loss Of Drive
danhebron54
, Nov 23 2008 03:24 PM
7 replies to this topic
Posted 23 November 2008 - 03:24 PM
Hi
I have a 1993 mini rio 1275 and i have lost all drive to the wheels, I can select all gears and the clutch is a in good condition and working properly, I lost drive whilst driving at about 40 in 4th and now it just makes a wiring noise when ever i try to pull away, any help would be greatly appreciated.
Dan.
Dan.
Posted 23 November 2008 - 03:46 PM
has one of driveshafts come apart from the cv joint?
or it could be the gearbox is jamming
have u changed anything on the car recently?
Posted 23 November 2008 - 06:26 PM
could be one or two things may be three , clutch disc has been stripped from its centre splined hub or you have snapped the shaft that should be holding the diff pinion , diff output spline stripped - into pod joint , none are easy to pin point without some stripdown ,
Posted 23 November 2008 - 06:56 PM
Hi
Dan.
Not changed anything and drive shafts are both ok, I can still push the car, would i be able to do that if the gear box had jammed?
Posted 23 November 2008 - 07:09 PM
can you engage any gears without using the clutch peddle ??? if yes i'd go for the disc has been shredded - not that uncommon .
Posted 23 November 2008 - 07:11 PM
Thanks for your help looks like I'll have to do some stripdown.
Posted 23 November 2008 - 07:13 PM
Simple...
Drain the oil, if metal bits come out then it's the gearbox/diff...
If not suspect the clutch.
Posted 23 November 2008 - 10:32 PM
Thanks I'll give it a try.
