Which Engine Stand To Buy?
41 replies to this topic
#31 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 November 2008 - 10:45 AM
£30... + P&P
The cost was justified when you consider the weight of the material necessary and the cost of welding and coating...
Certainly if I were to get some made it would be no cheaper than that...
But what you have to consider is, you have a 'universal stand' which does not really fit a mini engine... you are buying a purpose built adapter which is the interface between that stand and a specific engine...
#32 drummerian
drummerian
  • 1,674 posts
Posted 27 November 2008 - 10:47 AM
yeah i relise alot goes into it. Just seems unfortunate that the stand doesnt already how the a series :P
#33 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 November 2008 - 10:50 AM
You could 'modify' the original stand plate.... would not be much use for another type of engine when fitted, and you may experience clearance issues when turning the engine...
#34 drummerian
drummerian
  • 1,674 posts
Posted 27 November 2008 - 10:53 AM
i may buy one and have a look, are there any picutres online of the brackets you would make? so i can see whats up :P
#35 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 November 2008 - 11:06 AM
I've been looking for my original drawings, but can't find them anywhere., so given a few minutes spare, will measure up the last one I had made which was altered to allow for a better balance of the unit ( basically the pivotpoint was nearer to the centre of gravity of the engine )
#36 drummerian
drummerian
  • 1,674 posts
Posted 27 November 2008 - 11:13 AM
sounds good! thanks guessworks.
#37 mike.
mike.
  • 6,176 posts
Posted 27 November 2008 - 11:48 AM
So are there any other adaptors with that stand oli?
I can't see how those 4 little 'prongs' can hold anything!
Have you got any pics of your stand in action GW? :P
#38 Ethel
  • 26,029 posts
Posted 27 November 2008 - 12:18 PM
The prongs will be ok but they rely on the engine for rigidity
#39 mike.
mike.
  • 6,176 posts
Posted 27 November 2008 - 05:51 PM
Well is there not any extensions that go on the prongs and hold the engine like a forklift type thing that you could put round the block?
#40 oli8925
oli8925
  • 2,260 posts
Posted 27 November 2008 - 07:41 PM
all you get with the stand is in my picture. those four little prong things are about 1.5" long. bit poo really. i dont fancy modifying the standard plate, so i guess its down to getting an adapter. guessworks, how much interest would be enough to have you make some up?
bit *rubbish* as i was wanting to slap the engine on it on sunday when it comes out, because im borrowing wilson1275's uncle's crane, so will ony have it for that day. i suppose i might be able to stick it on an old skateboard i have for the time being just for mobility. it is an invincible skateboard!
#41 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 27 November 2008 - 09:59 PM
If you do a search i put up a topic on the technical section about 6 months ago, there are some photo's on that if they are still there.
I have the smaller Clarke 3 wheel stand and had the same problem with mounting it, you can drill holes in the slotted plate the arms bolt to, but I dont know how well it will spin round and it is trial and error to get a nice balance point.
In the end I got an adaptor from Spitfire bob. Very sturdy and well made, it bolts to the alternator bracket bolts, yes its a bit of a heart stopper at first but worked fine, even with the engine fully bult.
#42 oli8925
oli8925
  • 2,260 posts
Posted 28 November 2008 - 12:13 AM
thanks kerrin. id rather have the adapter plate i think. if a jobs worth doing its worth doing properly and all that
http://www.theminifo...x...c=74636&hl=
Edited by oli8925, 28 November 2008 - 12:15 AM.
