Ok well i have two eaton superchargers, one has matt black rotors and one has smooth silver rotors.
The one with silver rotors is from a 2002 Bini according to the sticker and the matt black one is from a 2004 Bini.
So im guessing the one with matt black rotors is best? but can somone confirm this as i want to start modifiying it so i can fit it to my engine.
Eaton Charger
Tomf
, Nov 24 2008 02:19 PM
4 replies to this topic
Posted 24 November 2008 - 02:19 PM
Posted 24 November 2008 - 03:10 PM
If I remember correctly the newer ones were teflon coated (hence being black) I can't remember why they changed them but i'll try to find out for you.
Posted 24 November 2008 - 03:16 PM
Ok here goes,
The teflon coating acts as a sacrificial layer so when the charger is at its hottest temp the teflon will have eroded away against the casting of the charger creating a better seal. This in turn makes the charger more efficient and according to people on Mini2 gives the charger an increase of around 0.1 bar in pressure. Also it can handle hotter temperatures.
Posted 24 November 2008 - 03:40 PM
Looks like ill be using the teflon coated charger then. Ill start working on it now
Posted 24 November 2008 - 05:04 PM
that'll be the one i sold you right?
