you might check my 100BHP thread...lol
http://www.theminifo...x...=79995&st=0
Rob
Hi Rob I enjoyed reading your injection tuning thread, i did consider a simular route myself some years ago, out of intrest I have a few questions/suggestions for you, for give my if i'm telling you to suck eggs.
You said about using a modded ECU what exactly do you mean, has it been remapped?
274 cam how are you going to deal with the vacuum, the lower vacuum may give problems with emmisions at idle.
you can dampend the vacum pulsing with a small vessel the injection vapour trap helps.
I did alter fuel pressure by shimming the standard fuel pressure regulator.
I tried porting the SPi inlet manifold and found that removing the lugs gave fueling problems between the inner and outer cylinders.
I also reshaped the throtal body to inlet plastic spacer and reshaped the butterfly shaft.
