Clutch Not Lifting Easily
Posted 27 November 2008 - 10:10 PM
clutch was working fine but all of a sudden one morning it decided to break itself
it will not change gear unless i slam the clutch to the floor, and feels extremley light
also when idling in gear tries to stall a little,
getting into gear is particuarly difficult when putting it into gear after stopped at traffic lights, quite embarrasing too. haha
anyway i thought maybe i could adjust clutch cable to pull clutch farther??
any ideas...
would appreciate help asap
thanks... andy
Posted 27 November 2008 - 10:20 PM
If it's dropped suspect the clutch slave cylinder seal to be the culprit.
Posted 27 November 2008 - 10:24 PM
expensive job.. dare i ask?
Posted 27 November 2008 - 10:26 PM
Posted 27 November 2008 - 10:29 PM
Posted 28 November 2008 - 09:15 AM
Re-fill the master and with the aid of an assistant, bleed the clutch system.
If you are still experiencing problems after that ( and you are getting full travel on the clutch arm ) then it's likely to be mechanical... possibly the clutch release bearing which may have collapsed...
Posted 28 November 2008 - 09:12 PM
Posted 28 November 2008 - 10:54 PM
Posted 29 November 2008 - 02:08 PM
im stuck without a clue lol
any ideas?
Posted 29 November 2008 - 06:09 PM
Posted 29 November 2008 - 06:13 PM
Posted 29 November 2008 - 07:04 PM
Posted 29 November 2008 - 07:06 PM
rover mini 1990 1300 kawasaki green
http://cgi.ebay.co.u...em=270310261886
just want to get the clutch sorted asap
Posted 29 November 2008 - 07:37 PM
i had a look where the cluth fluid goes, looks half full to me, does that sound ok?
Half full? It should be full to the brim!
Are you looking at the right fluid reservoir?
This is the slave cylinder, so check there's no leaking brake fluid around it: -
Posted 29 November 2008 - 07:53 PM
correct?
