So i got my head back from MED (stage 3 road comp for MPI) couldnt be happier. It was the last piece left before i could get the engine built up.
Fitted the head to the block last friday, my spec is...
MED head
swi5 cam (injection)
duplex timing gear
swiftune 1.5 rockers
new oil pump (swiftune)
Burlen 52mm throttle body
Customized manifold (opened up and gas flowed +polished)
Bored to 1293cc
New pistons and rings
Gearbox totally rebuilt inc s/c drops and 3.4 final drive
central oil pickup
maniflow LCB and twin cat to back system and de-cat pipe
new bosch lambda sensor (relocated to take in all 3 branches)
K&N element (also will try the induction kit)
Fuel pressure regulator
Clutch i had was fine (only 32000 on it)
Now ive it in the car built etc. Its turning over but will not fire up!
Im earthed all ok, checked all the sensors they seem fine.
My plugs are sparking ok, but the only thing ive noticed is the strong smell of petrol.
Now im thinking and correct me if im wrong, could the pressure reg need adjusted as currently its pushing to much fuel out and soaking the plugs (took them out and they seemed wet)??
Everything else seems ok. I know the clutch throws the timing of slightly if not fitted corectly it will not help starting, but it just went on ok at the time, did it need to be set to a certain position?
Ive just added an oil pressure gauge and from it (not sure how accurate it is) im not building up much oil pressure as im churning it over.
Would a new set of HT leads and plugs maybe help?
If anyone has fitted and pressure reg to an MPI before take a pic of how you have it plumbed in so i can compare, it does make the odd moaning noise as you turn the key to pump the fuel from the tank.
Any help would be great as i know some of you are pretty ggod with this sort of thing. Thanx guys!
Edited by tony kenobi, 02 December 2008 - 10:05 PM.
