Miss Fire
Posted 09 December 2008 - 04:23 PM
I've got a Mini Cooper S Works 1999 twin point injection and the engine is miss firing on tick over and upto 2000 rpms?
I have had a garage check the plugs, cables, distrabution, but still the same problem.
The mechanic thinks it could be the oxygen sensor or the cat back, but is not 100% sure? I don't what to buy both parts. Credit crunch!!!
Can anybody advise which part, or if it is another problem?
Stuart
Algarve
Portugal
Posted 09 December 2008 - 07:49 PM
Is the missfire regular or irregular?
What are the exhaust emissions results like? Any decent garage should have a four gas analyser even in portugal and they should be able to tell you HCs, CO%, O2% and CO2% and if you are real lucky you might find a garage with a five gas analyser which also gives NOX%
That will give you the biggest clue. Then there is the oxygen sensor itself, is this functioning correctly and the best way to test that is with a diagnostic unit connected to the ECU. This will also tell you what the sensors are reading so you can compare with actual measured temperature. I did a write up on testing the oxygen sensor using simple tools, its in the pinned topics at the top of this section of the forum. One other thing to consider is the oxygen sensor relay. I myself had been chasing a missfire at idle for a long time. I eventualy found that the relay was faulty. this caused the oxygen sensor to read a constand high voltage, other symptoms included a clean spark plug, almost looked new, no soot whatsoever.
Other things to consider is that it might not be the fault of the electronics, it could be mechanical. Has a compression test been carried out? whats the mileage on the car? Valve clearancies set correctly? Correct spark plugs for the engine?
Posted 10 December 2008 - 08:47 AM
I think you could be right about the garage. They don't install confidence. I'll go else where.
The missfire is irregular.
I'll go to another garage and get the exhaust emission test and also a compression test.
The milage is low 20700.
Valve clearance is set at .016 - .406mm this was the setting I was given by John Cooper garage.
The spark plugs are quite new and the same as the original specified.
I'll have a read of your write up regarding the oxygen sensor.
I guess it's just a process of elimination!
Thanks again.
Posted 26 February 2009 - 05:18 PM
First thing I will say is, how will the cat cause the engine to misfire? sounds like a statement from a garage that doesnt know what they are doing.
Hi Spocket,
I've been away for a while and only just got the emissions CO% reading which varied from 6.25 to 6.75! and the oxygen sensor lambda came out at 0.745.
Does that give any indication of the problem?
Would appreciate you advise.
Portugal
Posted 26 February 2009 - 09:18 PM
Posted 27 February 2009 - 10:43 AM
Thanks anyway.
