R1 Engine Breather Connections
9 replies to this topic
#1 YIANO
YIANO
  • 210 posts
Posted 17 December 2008 - 02:43 PM
can anybody post a pic up which shows the engine breather connections as I'm having trouble in particular the two brass coloured metal pipes one on the left and one on the right of the bank of carbs on the 5jj engine also any other info on where stuff goes would be great
#2 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 17 December 2008 - 06:04 PM
pm alexcrosse - he'll know. ;D
#3 alexcrosse
alexcrosse
  • 3,786 posts
Posted 17 December 2008 - 06:24 PM
they dont go anywhere... there is a vacuum on the the block that needs blocking or attaching to scottoiler, a big breather on the gearbox which needs to go to atmosphere along with carb ones
Edited by alexcrosse, 17 December 2008 - 06:26 PM.
#4 YIANO
YIANO
  • 210 posts
Posted 19 December 2008 - 02:49 AM
thanks alex, to clarify ive uploaded a couple of pics, id appreciate it if someone could tell me if im right in venting these to atmosphere
1 left carb breather - vent to atmosphere
2 engine vacuum - block off
3 right carb breather - vent to atmosphere
4 unknown what is this ? - it has pipework with a t piece -what do i do here?
thanks !
#5 alexcrosse
alexcrosse
  • 3,786 posts
Posted 19 December 2008 - 05:15 PM
si correcto, your photo is so close of number 4 i have noooo idea what or where it is
#6 YIANO
YIANO
  • 210 posts
Posted 19 December 2008 - 08:14 PM
Its sitting below number 4 carb and next to the starter motor any ideas ?
#7 R1mini
R1mini
  • 1,387 posts
Posted 20 December 2008 - 10:25 AM
I believe no4 is part of the AIS system but I'm not absolutely certain, I completly removed the AIS system on mine, the bolt to the right is the cam chain tensioner
David
Edited by R1mini, 20 December 2008 - 02:06 PM.
#8 YIANO
YIANO
  • 210 posts
Posted 20 December 2008 - 07:51 PM
cheers david I'll leave the ais connected and reroute the breather
#9 preston-7
preston-7
  • 90 posts
Posted 12 May 2009 - 05:05 PM
Hi, This is exactly what i've been looking for, but can someone please clear a couple of other things up- My engine breather is under the the middle of the carbs not on the end, is this significant? and if so does it still need blocking off? also, the pipe above number 3, mines dosen't have thast plastic bit on it? what is that for and what am I supposed to do with it?
there are also 3 pipes that are coming up the left hand side of the engine ( as if you were sitting on the bike ) i see one of them is attatched in picture 3, just to the right of the engine breather, where do the other two go? one has what looks like a built in filter of some sort? sorry for all the questions, I just don't know where i'm supposed to put everything!
thanks
Nick
Edited by preston-7, 12 May 2009 - 05:06 PM.
#10 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 12 May 2009 - 06:04 PM
Just to clear up, no4 is not the AIS system, the AIS is on the back of the engine directly above the oil filter, it has four pipes leading to each of the exhaust ports as below
As for no4 I'm sure thats the carb vent hose holder box as below, as R1mini said the cam chain tensioner attaches using the two holes on the furthest right
Carb vent hose with all the pipes attached
Sorry guys I'm not sure where the ends of the above hoses attach to, I didn't get a carb with mine and I got a load of bits in a separate box.
Hopefully the above might help a bit
:D
