Fuel Leaking From Filler Cap
Posted 26 December 2008 - 07:26 PM
2 questions, 1 how do I stop the fuel comming out?
2, how do I remove the staining?
all help gratefully received
Zed
Posted 26 December 2008 - 07:34 PM
I've seen petrol splashing out of my mates old Mini when he took a bend too fast and that was just after filling it right up whilst heading for a Mini show.
Is the filler neck top (where the cap sits) in good shape and not bent or damaged in any way?
How about the fuel vent pipe that attaches at the top of the fuel tank. Is that chaffing or snagged and not able to vent out through the boot floor?
Oh and I imagine you don't need a vented fuel cap, so if you've fitted a vented cap, could that be causing the problem?
Edited by taffy1967, 26 December 2008 - 07:35 PM.
Posted 26 December 2008 - 07:36 PM
Posted 26 December 2008 - 07:38 PM
new seal may be a good move
He's already fitted a new filler cap.
As for the staining, perhaps a good car polish will sort that out?
Posted 26 December 2008 - 07:44 PM
Zed
Posted 26 December 2008 - 11:07 PM
The early caps had a dismal seal on them which could let fuel ooze out, particularly if you were parked sideways on a hill or slope. Not filling the tank so close to the top is the first fix. The second possibility is to make a second rubber sealing ring and fit it to the cap in addition to the one that's already there. I rebuilt the caps that are on my car by using two such layers of rubber rings separated by two layers of thin Teflon sheet (also cut into rings). The thicker rubber layers "squish" to make the seal. The Teflon rings slip over each other to allow the rubber rings to slip relative to each other and seal without distorting as you tighten the cap.
Posted 26 December 2008 - 11:42 PM
Z
Posted 26 December 2008 - 11:43 PM
z
Posted 26 December 2008 - 11:47 PM
Posted 26 December 2008 - 11:51 PM
need some room in there for when the temperature changes because the fuel tank expands and tightens
Posted 26 December 2008 - 11:52 PM
try bit of G3 for the staining
peace x
Posted 27 December 2008 - 06:14 AM
I didnt know that there are 2 different types of caps, one which is green on the inside and one which is red.
The lugs on the filler caps are different thickness for the earlier and later style tank necks,I believe the earlier ones were the red type and later the green type.
I was using a green cap on a 1980's clubman tank earlier on this year and it was spewing fuel everywhere, i literally could fill it up and after 2 bends it had gone down to 3/4 a tank. I swapped it for a red cap off my 1980's roundnose and the problem was solved right away.
Regarding the paint im not too sure, best off asking in the paint section the lads in there will suggest something.
Posted 27 December 2008 - 08:01 AM
Posted 27 December 2008 - 09:35 PM
i had the same problem as many people on here have especially when turning right, this is a common problem, i got myself a new tank with one of those stop flap in them, i think they were in the later coopers, I tried new caps without success
The stop flap was fitted to prevent owners from filling up with anything other than unleaded fuel.
So yes it got introduced with the Rover Cooper in 1990 I believe as that was the first model to get a cat fitted as standard?
Posted 28 December 2008 - 07:23 PM
I may need to get that panel resprayed as all the paint along the seem has bubbled up and I have just rubbed it off. I have cleaned up the area with a prepaint cloth and using my halfords touch up kit, put a layer of grey primer where all the paint came off. It looks awful! but I have some touch up paint from the respray and I'll give it a go later.
Z
