Windscreen Fillet Tool
35 replies to this topic
#1 mini mark
mini mark
  • 876 posts
Posted 02 January 2009 - 08:02 PM
do you relly need to buy this tool to fit the chrome insert or can you just use a rubber hammer or somethink
thanks mark
link for the tool http://www.minispare.....20FILLET TOOL
#2 Scotauto
Scotauto
  • 335 posts
Posted 02 January 2009 - 08:03 PM
The tool makes it much easier but it can be done with a flat headed screwdriver.
#3 JohnGordon
JohnGordon
  • 966 posts
  • Local Club: N.W Mini's / O.D.M.C
Posted 02 January 2009 - 08:04 PM
you don't need it but it does make things easier although the one I bought from minispares bent out of shape before I'd even done half of my windscreen!
#4 plantfitterRich
plantfitterRich
  • 316 posts
  • Local Club: not sure yet!
Posted 02 January 2009 - 08:05 PM
Buy the tool! it makes life so much easier and its something to put in the tool box and own all your life. i used circlip pliers and about ten pairs of hands once, its just not worth the ball ache for under a tenner.
#5 mini mark
mini mark
  • 876 posts
thanks for the quick replys i think ill save my self a few quid
mark
#6 cherryblossom
cherryblossom
  • 450 posts
  • Local Club: medievil minis
Posted 02 January 2009 - 08:08 PM
it is good to have one, but i bought from from mini spares and my bent out of shape like straight away like said above = angry bf as only half finshed windscreen, just worried about buying a new one incase it does it again. :D
#7 EatSleepJDM
EatSleepJDM
    previously known as 88minicity
  • 631 posts
  • Local Club: Blakehill Minis
Posted 02 January 2009 - 08:09 PM
I got mine from Minimail made it so much easier than a metal coathanger
:D
#8 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 02 January 2009 - 08:11 PM
try frost and moss for them.
I used one with a roller, which was alot better then the ones without rollers.
I guess you must be using it wrong to bend one, as all it does is spread the rubber so the chrome can slide into it easily.
I always use abit of soapy water on the rubber to ease things along.
#9 JohnGordon
JohnGordon
  • 966 posts
They are useful but the minispares one needs to be stronger! If you are going to use a screwdriver please be very very careful as you don't want to put several deep scratches down your new paint work like someone did! :wacko: :D
#10 cherryblossom
cherryblossom
  • 450 posts
Posted 02 January 2009 - 08:13 PM
[quote name='Jordie' date='Jan 2 2009, 08:11 PM' post='1279382']
[/quote/]
maybe but we used it on his mini before did mine and it was alright oh well screwdriver did the job all right :D
#11 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 02 January 2009 - 08:16 PM
I made my own :D Cost = 0.00p, Effectiveness = 100%
#12 mini mark
mini mark
  • 876 posts
Posted 07 January 2009 - 03:31 PM
I made my own ;D Cost = 0.00p, Effectiveness = 100%
having a bit of troble getting mine in so how did you make your own and is there any tips that anyone has to make it any easier
thanks mark
#13 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 07 January 2009 - 04:03 PM
If your time is for nothing!!!!
#14 HARBER07
HARBER07
  • 4,498 posts
Posted 07 January 2009 - 04:12 PM
Haha. Basically i just chopped the end of a screwdriver, bent a bit of 1.2mm steel rod in a diamond shape, then welded that to the end of the screwdriver. Ill get some pics up if i remember.
#15 mini mark
mini mark
  • 876 posts
Posted 07 January 2009 - 04:57 PM
so i just want somethink to open up the rubber up with
i would buy the tool but as i have just been made redundent need to try and save as much as possible
thanks mark
