Fitting a turbo to a 1275
Posted 06 August 2005 - 05:52 PM
cheers,
dave :wink:
Posted 06 August 2005 - 06:10 PM
Edited by CharlieBrown, 07 August 2005 - 11:11 AM.
Posted 06 August 2005 - 07:25 PM
Posted 06 August 2005 - 09:42 PM
Very informativei spent £500 turning my 1275 cooper into a 1275 turbo....then a fair wedge about 6 weeks after that when i melted the f**ker!
What was it, too much boost???
Posted 07 August 2005 - 10:03 AM
after that i took the time to read through everything on turbominis and learnt a hell of a lot, now its running 15psi and loving it
Posted 09 August 2005 - 10:19 AM
It's not a project to be taken lightly, you need to have a decent lump of cash put aside as there's a lot to consider. Done badly a Turbo engine will be a nightmare, done properly it will leave you with a permanent smile !was just woundering how much it would cost to turbo a 1275.
cheers,
dave :wink:
You'll obviously need a Turbo, inlet/exhaust manifolds, sealed carb, regulator, pump etc etc All these can be picked up from eBay, various forums etc
you'll need to fit a larger fuel feed, and fit a return and cut the bulkhead and weld in a box, would you be able to do this ? if not you'll have to pay somebody.
The final cost will depend on how much you can do yourself really. If you can do all of the work yourself and source all the parts quite cheaply, then it shouldn't cost a massive fortune, but it won't be cheap either .......
Phil.
Posted 09 August 2005 - 01:59 PM
what size fuel feed and what size return please? Also where should I put the return? At the top of the tank?you'll need to fit a larger fuel feed, and fit a return
Much appreciated, because I can help my friend along with his project, I've got two spare tanks.
Posted 09 August 2005 - 02:10 PM
8mm return at top of tank and 8mm feed. What is the standard size fuel feed then?
Posted 09 August 2005 - 02:18 PM
Can't remember the Metro sizes off hand, though i have it written down somewhere ....
Phil.
Posted 09 August 2005 - 02:27 PM
Posted 10 August 2005 - 05:35 PM
Posted 11 August 2005 - 10:51 AM
